Moonroof question.....
Old Nov 13, 2003 | 08:03 PM
Bulldogg83's Avatar
Default Moonroof question.....
Sooo.....my moonroof works perfectly fine when it is warm outside, but now that it has gotten cold it won't open at all. It won't vent up nor will it move back into the hood like it's supposed to. Do you think that the motor for it is going bad or what???
Old Nov 13, 2003 | 08:12 PM
smeister's Avatar
Default Re: Moonroof question..... (Bulldogg83)
Doubt it...could just be sticky from the cold and stuck.
Old Nov 13, 2003 | 08:13 PM
Bulldogg83's Avatar
Default Re: Moonroof question..... (smeister)
I've tried pushing the open button and then pushing gently with my hand and nada
Old Nov 13, 2003 | 08:51 PM
RyanEJ8's Avatar
Spray some silicone lube on the tracks.
Bulldogg83's Avatar
Default Re: Moonroof question..... (RyanCivic2000)
alright I'll try that this weekend...
Old Nov 18, 2003 | 07:35 PM
smeister's Avatar
How can he spray it on the tracks if he cant open the moonroof?
Old Nov 18, 2003 | 08:38 PM
Mohudsolo's Avatar
What counts as cold in Dallas? Mine wouldn't open when cold either, but I consider cold to be below freezing and mine was frozen shut. Did the motor sound like it was straining or turning?
Assuming it is not frozen, carry the lube in the car and next time it's warm enough to open, spray the tracks then. Use one with the spray wand so you don't spray it all over though.
Old Nov 19, 2003 | 08:13 AM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smeister &raquo;</TD></TR><TR><TD CLASS="quote">How can he spray it on the tracks if he cant open the moonroof?</TD></TR></TABLE>
He said it opens fine when its warm and has a hard time when its cold. Wait until its warm and then spray silicone.
Old Nov 19, 2003 | 08:19 AM
haggar's Avatar
Might also consider replacing the seals. They might be old and stiffening up.
In general, the seals on a moonroof are much less compliant when cold, requiring more force from the motor.
Hehehe, its my job, ya see. I currently design 'smart' motor electronics for moonroofs. Ours have to work correctly at -40 degrees. We see a major increase in force required once the seals get cold.
Old Nov 19, 2003 | 09:15 AM
Bulldogg83's Avatar
Default Re: Moonroof question..... (haggar)
thanks for all the help guys...I'll let you know how it works out
fwdftw
Feb 11, 2007 01:35 AM
Spicoli v 3.0
Audio / Security / Video
Feb 20, 2006 01:55 PM
Doeboy
Dec 5, 2004 10:44 AM
soloteg
Apr 4, 2003 08:28 AM
