Dynamat in the cold?
Old Feb 17, 2006 | 11:08 AM
Spicoli v 3.0's Avatar
Default Dynamat in the cold?
Any conflicts with laying dynamat in the cold like below freezing?
Old Feb 17, 2006 | 11:13 AM
MLD211's Avatar
Well other than it wont sick, No
I suppose it depends, the extreme may work. Or if you use a heat gun and heat the dynamat and the surface first that would probly work.
Old Feb 18, 2006 | 12:32 AM
Sex Cells's Avatar
a heatgun and roller would probably do the trick. do you have a garage to put it in? and possibly a heater? im not sure how well it will stick to a cold surface. possibly heat up the surface first.
Old Feb 18, 2006 | 08:51 AM
fcm's Avatar
fcm
Old Fart
Default Re: Dynamat in the cold? (Spicoli v 3.0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spicoli v 3.0 &raquo;</TD></TR><TR><TD CLASS="quote">Any conflicts with laying dynamat in the cold like below freezing?</TD></TR></TABLE> I will have to agree with the above, a cold surface and cold Dynamat will be very hard to apply properly, when we install Dynamat we not only clean the surface, we will heat the surface and the "sticky" side of Dynamat, and then as we apply it we use the heat gun to heat the outside so it is easier to not only "mold" the Dynamat to uneven surfaces. We find it sticks much better. we us this method with all types of "dampening" materials.
Remember the most important thing is a clean surface.
IMO I would find a heated space to do it in, even if you have to pay, would be sad if you spent good money on Dynamat, and then have it all fall off because it wasn't applied properly, kind of a wast of time and effort not to mention money. 94
Old Feb 18, 2006 | 09:33 AM
JoshuaVTEC's Avatar
It was about 40 here yesterday and I did this Extreme with no problems.
Old Feb 18, 2006 | 09:48 AM
fcm's Avatar
fcm
Old Fart
Default Re: Dynamat in the cold? (JoshuaVTEC)
Check it again in 6 months. 94
Old Feb 20, 2006 | 01:55 PM
Sex Cells's Avatar
Default Re: Dynamat in the cold? (fcm)
i'd double up
hassan21
Sep 27, 2007 07:25 AM
lolumad
Honda Civic (2006 - 2015)
23
May 25, 2007 02:59 PM
Tigfab
Welding / Fabrication
Apr 2, 2006 06:36 PM
markysparky
Oct 27, 2005 06:55 PM
608 Gangsta
Oct 18, 2004 01:12 PM
