what is wrong with my motor??!?! i cant figrue it out....
Old Nov 13, 2003 | 10:26 AM
gdrum's Avatar
Default what is wrong with my motor??!?! i cant figrue it out....
Okay so i have an h22a4....and at the beginniing of every gear it bogs for a lil second..then takes off and screams....idles fine...but just like when you take off in 1st...or just mash it in 4th...or 3rd...itll bog then take off and scream. I changed the plugs....wasnt them. So im thinking fuel pressure regulator? or bad plug wires? suggestions please...
Old Nov 13, 2003 | 10:32 AM
Wiseguy619's Avatar
Default Re: what is wrong with my motor??!?! i cant figrue it out.... (gdrum)
i had a similar problem with an integra i had recently bought as my beater. When i test drove the car, it bogged when I mashed on it. I checked out the plugs and wires and found that one of the plug wires was bad. It turns out i was only running 3 out of 4 cylinders, so it would bog when i was over 3000 rpm. I changed the wires and BAM! Good as new
Old Nov 13, 2003 | 10:39 AM
mhgleitz's Avatar
sounds to me like your problem is fuel/fuel supply related. are you getting any engine codes?
Old Nov 13, 2003 | 11:03 AM
rjr162's Avatar
Default Re: what is wrong with my motor??!?! i cant figrue it out.... (mhgleitz)
I think every 5th gen has this problem
Old Nov 13, 2003 | 11:41 AM
93ludeSi's Avatar
just curious, how many miles on the clutch, i have seen worn out clutches slip a little going into each gear cause the car to hesitate a little
Old Nov 13, 2003 | 06:12 PM
jdm22vtec's Avatar
Default Re: (93ludeSi)
check the fuel pressure...
Old Nov 16, 2003 | 08:46 AM
gdrum's Avatar
Default Re: (jdm22vtec)
clutch is brand new, buying new wires today.....i hav aftermarket fuel pressure regulator but no gauge so i cant tell the pressure....
Old Nov 16, 2003 | 10:12 AM
Matgallis's Avatar
Default Re: what is wrong with my motor??!?! i cant figrue it out.... (rjr162)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjr162 &raquo;</TD></TR><TR><TD CLASS="quote">I think every 5th gen has this problem</TD></TR></TABLE>
eh no...
Old Nov 16, 2003 | 12:20 PM
gdrum's Avatar
threw this code..... 7 short.... 1 long.....2 short
Old Nov 16, 2003 | 12:27 PM
gdrum's Avatar
7 short.....pause 1 long 2 short....so 7 and a 12 id assume right..and what would my problems be
Old Nov 16, 2003 | 01:15 PM
jdm22vtec's Avatar
7) TP Sensor (Throttle Position)
defective circuit or unplugged / defective sensor
12) EGR Lift Sensor (Exhaust Gas Recirculation)
these codes are for prelude motors 85-98
here is a helpful link for ecu codes
http://tech.hybridgarage.com/tech/codes.html
Modified by jdm22vtec at 5:28 PM 11/16/2003
Old Nov 16, 2003 | 01:43 PM
gdrum's Avatar
Default Re: what is wrong with my motor??!?! i cant figrue it out.... (jdm22vtec)
i dont think these would have anythign to do with my bogging problem eh...prob fuel or wires...ill check those and go from tehre i guess
Old Nov 16, 2003 | 01:55 PM
gdrum's Avatar
i have a hiflow cat and whatnot so i understand the 12..but is the 7 code bad? what do i have to do to fix it..or where would i look
Old Nov 16, 2003 | 02:09 PM
Goinfasterthanu's Avatar
you need a guage i bet your running lean!! When i bought my fpr it was set VERY lean when i first put it in....
Old Nov 16, 2003 | 03:43 PM
SKDRCR's Avatar
Default Re: (Goinfasterthanu)
I doubt it's your wires,
have you pulled them and looked at them?
Old Nov 16, 2003 | 05:17 PM
gdrum's Avatar
Default Re: (SKDRCR)
my wires are old, and just oem ones.....imma change them anyways...im thinkn fuel pressure not sure though
CS!
15
May 23, 2013 05:23 AM
landon2992
Oct 13, 2010 04:43 PM
CRiSP
Jul 4, 2005 10:23 AM
spock_rocker
Apr 20, 2004 05:35 PM
Hondasaurs
Jan 23, 2003 06:26 PM
