Broken TPS...does it matter?
Old Nov 13, 2003 | 10:14 AM
bambam's Avatar
Default Broken TPS...does it matter?
Hey guys...need help again...
I got my MPFI done...actually I just did the Si swap but when I put the engine in from the bottom, I broke off the TPS sensor completely so the wires aren't even connected to it. I still cant get my car to start. I've checked each cylinder and each cylinder is getting spark and fuel, actually too much fuel I think because each spark plug is soaked in fuel. and my cylinders are flooded. Could this be because of the broken off TPS? could my car be too flooded to start? How do I get all that fuel out of the cylinders? I have another TPS from a 2nd gen teg but just havent had time to put it on.
__________________
Old Nov 13, 2003 | 10:28 AM
Redline130's Avatar
Default Re: Broken TPS...does it matter? (bambam89lx)
Could be that your tps is sending the ecu the wrong voltage and making the ecu think that the engine is at WOT. Thus the over fueling issue. Go ahead and replace it and see if it helps.
turtlegrip
21
May 16, 2014 11:52 PM
xft
Jan 27, 2009 06:21 PM
ex_ricer
Aug 14, 2008 11:42 AM
Stray
Sep 27, 2007 11:45 AM
EvilPinkEye
Sep 1, 2006 10:20 AM
