dang...so what motor mounts and brackets do i need for a gsr swap into an ek?
i was told tranny mount and rear mount..and i got the brackets with them....will the rest of the d series mounts work??will the gsr ac bracket work?etc...thnx alot
there are 5 mounts/brackets total
1. bracket under cam gears: get one from an 99-00 civic SI
2. a/c bracket: you can use any b-series bracket but not all the bolts on the a/c compressor will bolt up, only two will bolt up. if you want everything bolt to bolt up, get a b-series bracket from a DOHC delsol (saying you use the d-series) compressor
3. rear mount under intake mani: you need one from a 99-00 civic SI (bracket that is shaped like a T
4. top tranny mount: you can reuse this mount from the civic
5. side tranny mount: you'll need one from a b-series motor
and all other mounts/rackets that are attached to the car and not the motor, you can reuse the civic ones..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzN_J_SpeC »</TD></TR><TR><TD CLASS="quote">there are 5 mounts/brackets total
and all other mounts/rackets that are attached to the car and not the motor, you can reuse the civic ones..</TD></TR></TABLE>
so for the rear mount..all i needed was the 99 si bracket??dang i bought mount and bracket
for side tranny mount..will any b series work?or only 99-00 si??cause i bought tranny mount and bracket
and dang..looks like i need the bracket from a 99-00 si from under the cam gears..the bracket/mount from the gsr wont work, correct?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GOLDBERG »</TD></TR><TR><TD CLASS="quote">so for the rear mount..all i needed was the 99 si bracket??dang i bought mount and bracket
You can use the mount also, but it's the same as your stock mount.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">for side tranny mount..will any b series work?or only 99-00 si??cause i bought tranny mount and bracket</TD></TR></TABLE>
If you are calling the front tranny mount the side tranny mount then you can use either a 99-00 Si or a 94-01 Integra bracket then reuse the stock Civic rubber mount that goes under the frame rail.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">looks like i need the bracket from a 99-00 si from under the cam gears..the bracket/mount from the gsr wont work, correct?</TD></TR></TABLE>
The GSR mount will not work, you need the 99-00 Si bracket and then reuse your stock mount. Once you get the Si bracket and compare it to the GSR bracket, you'll see the difference.
</TD></TR></TABLE>You can use the mount also, but it's the same as your stock mount.
dang..anything else i need to know?
i ordered 6, 7 i think..which others do i need mount wise..dang that ac bracket is pricey
if your swap didn't come with number 10, then u need that one. as for the a/c bracket, like i mentioned before you can use the one that came with the swap (if it came with one) but only two bolts will bolt up. it will hold until u get a a/c bracket from a dohc delsol. actually, im still only running two bolt for the a/c compressor, and have not had a problem yet. it's been about a yr now, since my swap..
SeVeNisOnE
18
May 21, 2008 03:02 PM
asocallocal
Apr 11, 2008 10:28 PM
SyDuck
Jan 28, 2005 06:59 PM
Check signiture below.
