Is a 5-spd tranny from a d16y8 1998 model, better than the 92-95 trannys?
Old Nov 11, 2003 | 05:27 PM
GreenBean's Avatar
Default Is a 5-spd tranny from a d16y8 1998 model, better than the 92-95 trannys?
I have a lot of bearing noise in my 93-cx wich has a 95 coupe sohc vtec swap in it, I can either tear into the tranny I have (145,000 miles) to replace all the bearings. Or I have a man that will sell me a cheap trans(@55,000 miles) that needs a main shaft bearing, out of a 98-ex coupe.
Is it true that the 96-00 models have steel shift forks and are better transmisisons b/c of this. Thanks in advance...
Old Nov 11, 2003 | 05:42 PM
BauleyCivic's Avatar
Risky Business
Default Re: Is a 5-spd tranny from a d16y8 1998 model, better than the 92-95 trannys? (GreenBean)
Yes. The 96-00 EX trannies have steel shift forks and are much stronger and durable compared to the 92-95 which have aluminum shift forks.
Old Nov 11, 2003 | 05:45 PM
SOHC_MShue's Avatar
Default Re: Is a 5-spd tranny from a d16y8 1998 model, better than the 92-95 trannys? (BauleyCivic)
they are stronger. Still not very strong though I don't think any d trannys are.
Old Nov 11, 2003 | 05:49 PM
The Internet Tough Guy's Avatar
Default Re: Is a 5-spd tranny from a d16y8 1998 model, better than the 92-95 trannys? (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote"> they are stronger. Still not very strong though I don't think any d trannys are.</TD></TR></TABLE>
yep. you've got your answer
Old Nov 16, 2003 | 12:42 AM
dremmel's Avatar
learning about trannys here is fun. will that need any modification? the 96+ onto a 92-95block? tossing around ideas for z6 swap soon.
Old Nov 16, 2003 | 01:02 AM
ace1875's Avatar
Default Re: Is a 5-spd tranny from a d16y8 1998 model, better than the 92-95 trannys? (dremmel)
NO ALL 88 AND UP D SERIES TRANNY IS BOLT ON
Old Nov 16, 2003 | 01:47 AM
mycivicstoo(s)low's Avatar
Default Re: Is a 5-spd tranny from a d16y8 1998 model, better than the 92-95 trannys? (ace1875)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ace1875 &raquo;</TD></TR><TR><TD CLASS="quote">NO ALL 88 AND UP D SERIES TRANNY IS BOLT ON</TD></TR></TABLE>Easy there, buddy.
Old Nov 16, 2003 | 01:48 AM
ace1875's Avatar
Default Re: Is a 5-spd tranny from a d16y8 1998 model, better than the 92-95 trannys? (mycivicstoo(s)low)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mycivicstoo(s)low &raquo;</TD></TR><TR><TD CLASS="quote">Easy there, buddy. </TD></TR></TABLE>
sry i didn't knew i had the caps on
Old Nov 16, 2003 | 09:41 AM
dremmel's Avatar
curious, my buddy might have to put a 88-91 tranny onto his 94 EG sedan.ok so it will bolt up. what's need to connect the tranny to his pedals? is there a special conversion kit for this? what will he need? any knowledge appreciated cuz most likely it'll be me helping him . im guessing the EF clutch cable...pedals..what about shift linkage?
Old Nov 30, 2003 | 07:02 PM
WangChung's Avatar
i thought 88-91 d-series were cable trannies. . .
Old Nov 30, 2003 | 07:11 PM
CaptinMcnut's Avatar
hell yah 96 trannys are way better than 92-95 but d series trannys still suck
Old Nov 30, 2003 | 07:19 PM
Risky Business
WRONG
92-95 and 96-00 Hydro Trannies are compatible...
88-91's are cable and require a special kit from HAsport to use
Old Nov 30, 2003 | 07:20 PM
JV's Avatar
JV
Who?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dremmel &raquo;</TD></TR><TR><TD CLASS="quote">curious, my buddy might have to put a 88-91 tranny onto his 94 EG sedan.ok so it will bolt up. what's need to connect the tranny to his pedals? is there a special conversion kit for this? what will he need? any knowledge appreciated cuz most likely it'll be me helping him . im guessing the EF clutch cable...pedals..what about shift linkage?</TD></TR></TABLE>
You will need a cable to hydro kit like this one: http://www.hasport.com/Product...C.htm
89civicb16a1
12
Dec 19, 2010 09:35 PM
Old School CRX Swap
May 23, 2006 09:53 AM
GdmLaz
26
Nov 15, 2005 02:23 PM
jdmekcivic98
May 2, 2005 07:32 AM
piscorpio
May 17, 2003 08:14 PM
