Is a 5-spd tranny from a d16y8 1998 model, better than the 92-95 trannys?
I have a lot of bearing noise in my 93-cx wich has a 95 coupe sohc vtec swap in it, I can either tear into the tranny I have (145,000 miles) to replace all the bearings. Or I have a man that will sell me a cheap trans(@55,000 miles) that needs a main shaft bearing, out of a 98-ex coupe.
Is it true that the 96-00 models have steel shift forks and are better transmisisons b/c of this. Thanks in advance...
Risky Business
Re: Is a 5-spd tranny from a d16y8 1998 model, better than the 92-95 trannys? (GreenBean)
Yes. The 96-00 EX trannies have steel shift forks and are much stronger and durable compared to the 92-95 which have aluminum shift forks.
Re: Is a 5-spd tranny from a d16y8 1998 model, better than the 92-95 trannys? (BauleyCivic)
they are stronger. Still not very strong though I don't think any d trannys are.
Re: Is a 5-spd tranny from a d16y8 1998 model, better than the 92-95 trannys? (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue »</TD></TR><TR><TD CLASS="quote"> they are stronger. Still not very strong though I don't think any d trannys are.</TD></TR></TABLE>
yep. you've got your answer
learning about trannys here is fun. will that need any modification? the 96+ onto a 92-95block? tossing around ideas for z6 swap soon.
Re: Is a 5-spd tranny from a d16y8 1998 model, better than the 92-95 trannys? (ace1875)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ace1875 »</TD></TR><TR><TD CLASS="quote">NO ALL 88 AND UP D SERIES TRANNY IS BOLT ON</TD></TR></TABLE>Easy there, buddy.
Re: Is a 5-spd tranny from a d16y8 1998 model, better than the 92-95 trannys? (mycivicstoo(s)low)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mycivicstoo(s)low »</TD></TR><TR><TD CLASS="quote">Easy there, buddy. </TD></TR></TABLE>
sry i didn't knew i had the caps on
curious, my buddy might have to put a 88-91 tranny onto his 94 EG sedan.ok so it will bolt up. what's need to connect the tranny to his pedals? is there a special conversion kit for this? what will he need? any knowledge appreciated cuz most likely it'll be me helping him . im guessing the EF clutch cable...pedals..what about shift linkage?
i thought 88-91 d-series were cable trannies. . .
Risky Business
WRONG
92-95 and 96-00 Hydro Trannies are compatible...
88-91's are cable and require a special kit from HAsport to use
WRONG
Re: Is a 5-spd tranny from a d16y8 1998 model, better than the 92-95 trannys? (dremmel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dremmel »</TD></TR><TR><TD CLASS="quote">curious, my buddy might have to put a 88-91 tranny onto his 94 EG sedan.ok so it will bolt up. what's need to connect the tranny to his pedals? is there a special conversion kit for this? what will he need? any knowledge appreciated cuz most likely it'll be me helping him . im guessing the EF clutch cable...pedals..what about shift linkage?</TD></TR></TABLE>
You will need a cable to hydro kit like this one: http://www.hasport.com/Product...C.htm
89civicb16a1
12
12-19-2010 09:35 PM
Old School CRX Swap
05-23-2006 09:53 AM
GdmLaz
26
11-15-2005 02:23 PM
jdmekcivic98
05-02-2005 07:32 AM
