gear grinding...is this the problem
Old Nov 10, 2003 | 06:23 PM
tyflip2's Avatar
Default gear grinding...is this the problem
recently my 2nd gear has been grinding if i shift over 5k. i also have had the problem that my tranny was leaking oil where the axle meets the tranny on the passenger side. could there be a lack of oil causeing the one gear to grind? i need help
Old Nov 10, 2003 | 06:43 PM
eg6h8k's Avatar
Default Re: gear grinding...is this the problem (tyflip2)
yes..not enough oil would make it grind.. theres a ruber seal where the axle and tranny meets up..u can get a new one..it should prevent it from leaking..dont **** up ur tranny anymore...this is an easy fix..gl
Old Nov 10, 2003 | 09:50 PM
tyflip2's Avatar
Default Re: gear grinding...is this the problem (eg6h8k)
even if it is only one gear that is grinding? i sure hope so
Old Nov 10, 2003 | 09:52 PM
clm's Avatar
clm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tyflip2 &raquo;</TD></TR><TR><TD CLASS="quote">even if it is only one gear that is grinding? i sure hope so</TD></TR></TABLE>
Hopefully. But I agree with the guy above. Replace the seal and put some fresh Honda MTF in there.
dc2[HI]
Aug 7, 2008 11:03 AM
Novtecdohc
Dec 15, 2005 09:09 PM
shawn_crx
Jun 29, 2005 11:18 AM
rac3rb0i
Nov 30, 2004 11:02 AM
TypeSH
Jun 9, 2002 12:00 PM
