CODE 22 VTEC OIL PRESSURE GSR EK!!!!!!!!
Old Nov 8, 2003 | 07:10 PM
AL ASPIRATED's Avatar
Default CODE 22 VTEC OIL PRESSURE GSR EK!!!!!!!!
everytime i rev my motor up to redline wen i race, the check engine light turns on. everytime i check it its a code 22(VTEC OIL PRESSURE SENSOR). i always reset it and drive it normally, but wen i rev up to like 8200-8500 RPMs, the CEL comes on.
Does this happen to other people? wat can be wrong? THANKS
Old Nov 9, 2003 | 06:21 AM
Echo7847's Avatar
Default Re: CODE 22 VTEC OIL PRESSURE GSR EK!!!!!!!! (JDMTyPeRHaTcH)
the oil pressure switch is either bad or there's a problem with the connection or the wires leading to it. It's the little green plug next to the vtec solenoid.
Old Nov 9, 2003 | 06:54 AM
well i did the swap into a 98 civic. wat connection wouldbe bad? i wired one of the wires to da ecu correctly and the other was a ground.
Old Nov 10, 2003 | 07:02 AM
Echo7847's Avatar
Default Re: (JDMTyPeRHaTcH)
Check the switch itself, it nay have gotten damaged before/during the swap. Do you have a helms manual? They provide a complete walkthrough for fixing this cel.
Old Nov 10, 2003 | 08:13 AM
Full Race EG's Avatar
Default Re: (Echo7847)
try to ground it out somewhere else. i have had this problem with a swap before.
Old Nov 10, 2003 | 04:29 PM
hondaZvic's Avatar
Default Re: (IntegraLStuner)
this must be a curse or something.... i just fixed the same thing on my car 2 days ago.. the last thing i thought it would be was the ground wire.. sure enough.. it was the ground wire...
Old Nov 10, 2003 | 07:49 PM
thanks for all your help you guys, imma try to re-ground my wire, and let you guys know whats up.
THANKS AGAIN
ejalex
Sep 14, 2012 11:25 PM
SinsEvil666
Sep 12, 2009 08:26 AM
drudy
Aug 26, 2005 12:20 PM
shadykit
Aug 2, 2004 06:11 PM
maggsgsr
Apr 20, 2004 02:37 PM
