Any negatives to high comp./ dished piston?
Old Nov 8, 2003 | 10:26 AM
naturelovindc2's Avatar
Default Any negatives to high comp./ dished piston?
My block is at RS getting sleeved and bored to 84.5mm. Arias has three compression ratios available in that bore: 9.1:1, 10.9:1, and 11.9:1. I decided against 11.9:1 because my car will see a decent amount of city miles, retain A/C, etc. I told them to send me the 10.9:1 pistons but checking the specs on the Arias web sight it stated that this piston has a -3 dish as opposed to the 11.9:1 piston with a 1.4 dome.
Are there any negative effects to running a dished piston? The car will be seeing nitrous to make up for the lower comp. ratio I went with and I didn't know if using these pistons would be a bad idea. Any insight would be greatly appreciated. TIA
Old Nov 8, 2003 | 11:01 AM
chris@allmotor.net's Avatar
Default Re: Any negatives to high comp./ dished piston? (naturelovindc2)
Id get the 11.9:1's..
Old Nov 8, 2003 | 11:08 AM
Default Re: Any negatives to high comp./ dished piston? (One.allmotor DA)
That was my initial plan. I had been talking to the same person there evrytime I called. One time I called with some more questions and he wasn't working. Another person at the shop asked me alot of questions about how I'll be using the car, goals, etc. He suggested the nitrous and lower comp. I have a NX wet system on my 5.0 mustang that's less than 6 months old. I was going to get a dry nozzle, 440cc injectors, and a hondata s200 to control the nitrous.
Old Nov 9, 2003 | 09:08 PM
bump. Anyone have a picture of one of these high compression dished pistons? I'm I'd like to see what they look like. I've always seen high comp. pistons with a dome that came up higher than the deck height and just can't imagine how a 10.9:1 piston could have a -3 dish. Any insight would be greatly appreciated.
Old Nov 9, 2003 | 09:18 PM
ArinX's Avatar
Wiseco 11.8 comp pistons 84.5 mm
Old Nov 9, 2003 | 09:29 PM
Default Re: Any negatives to high comp./ dished piston? (ArinX)
Looking at the right edge of the piston in the pics it looks like it has a slight dome. Is that really a dished piston?
Old Dec 23, 2003 | 01:42 PM
O.K. I'm stupid. I figured out that the plus and minus numbers meant cc's not the hieght of the dome or depth of the dish.
89si-rex
12
Dec 11, 2013 03:14 AM
bradabu
Aug 12, 2011 05:18 AM
Youlose1305
May 5, 2006 06:51 AM
elmo244
May 30, 2005 12:57 PM
B16Civic93
Apr 14, 2005 06:38 PM
