Honda S2000 Honda S2000
CLUTCH PROBLEMS! )= <===
Old Nov 7, 2003 | 04:35 PM
craziex8's Avatar
Default CLUTCH PROBLEMS! )= <===
hi.. just recently... i've been havin problems with my s2k.. i just got my engine head removed.. and fixed an exhaust leak.. that caused misfire and low compression on my 2nd and 3rd cylinder..
i waited about.. a month and a half to get my car out of the shop for that repair.. and i've been driving it this week.. and all of a sudden.. my clutch starts to feel like its not being as effective.. this happened all after a race.. =I
ne ways.. it felt like when u have to shift gears before.. it was harder to put it into gear.. now i can just lightly put it into gear.. it feels very weak and not as aggressive as before.. does ne one else have the same problems? comments? help?
thanks
p.s. - ne other known issue on s2k's??
i have a 2000 s2000 with 40,700 miles on it.. thanks a lot guys
Old Nov 7, 2003 | 06:38 PM
munckee's Avatar
Are you sure its not simply slipping?
Old Nov 8, 2003 | 10:19 AM
Mr. Bagel's Avatar
Default Re: CLUTCH PROBLEMS! )= <=== (craziex8)
so you slipped, burned and possibly glazed the clutch during a race, it's overheated and cannot grip worth a damn because you rode it all the way out and now you think you have a problem with the clutch?
just let it cool down and see if it persists or not.
Old Nov 9, 2003 | 04:18 AM
ScubaStevo80's Avatar
Default Re: CLUTCH PROBLEMS! )= <=== (Mr. Bagel)
S2000 tranny's are not the best, so I would be careful.
Either a) wait it out and see if there's any difference
b) Check to see if there was some sort of TSB On the clutch for your year
c) Get a new clutch
Old Nov 9, 2003 | 09:16 AM
OC 335i's Avatar
Default Re: CLUTCH PROBLEMS! )= <=== (VolpeOwnsU)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VolpeOwnsU &raquo;</TD></TR><TR><TD CLASS="quote">S2000 tranny's are not the best, so I would be careful.
c) Get a new clutch</TD></TR></TABLE>
S2000 trannies are some of the better trannies around!
Old Nov 9, 2003 | 11:22 PM
The HamsterBall's Avatar
if you have to replace the clutch, get an aftermarket clutch that grabs harder
since you race
Old Nov 10, 2003 | 12:02 PM
jerrypeterson's Avatar
Sounds like you misshifted and glazed the clutch. Bet it works fine now. Try focusing on smooth up shifts.
Jerry Powell
Honda CR-V & Element
Dec 27, 2012 06:06 AM
Cypher0117
16
Dec 9, 2009 08:36 AM
Hemix
11
Jun 30, 2008 11:25 AM
RainingRed24
Oct 11, 2005 01:47 PM
allmotorls95
Feb 26, 2003 02:44 PM
