Quick question about timing....
Where is the connector you have to use the jumper wire on to set the ignition timing? I have a 91 si, is the connector on the inside of the car down in kick panel? Also is that suppose to be connected to anything?
There is a yellow rubber cap that is on the left rear engine bay. you have to jump a Brown and Green-white terminals with a paper clip or some sort of jumper wire
If you need help with timing PM me
From: I told you to wait in the truck in Texas, United States
on the 90-91 models, it is on the passenger side kick panel
inside the car..
see: http://www.binghamtonlife.com/...8.jpg
taken from http://www.binghamtonlife.com/...t.htm
inside the car..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wicked B16 »</TD></TR><TR><TD CLASS="quote">There is a yellow rubber cap that is on the left rear engine bay. you have to jump a Brown and Green-white terminals with a paper clip or some sort of jumper wire
ok so I take it this was for 88-89?
redpeppers
Jul 25, 2005 09:39 PM
