burning oil
Old Nov 7, 2003 | 12:05 PM
imperialgsr's Avatar
Default burning oil
has anybody had a problem with msd sci ignition. i noticed when it was hooked up my car was burning oil, now i removed it and it still burns oil, could this have messed up the head gasket or piston rings. a month before that my igniter was loose and my car was miss firing. Ive checked the grommets on the valve cover and i have a little bit of oil on the top of my transmission looks like it coming from the head gasket. could there be any other problems that would make the engine burn oil.
Old Nov 7, 2003 | 02:03 PM
svtec's Avatar
L D E S
Default Re: burning oil (imperialgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imperialgsr &raquo;</TD></TR><TR><TD CLASS="quote">has anybody had a problem with msd sci ignition. i noticed when it was hooked up my car was burning oil, now i removed it and it still burns oil</TD></TR></TABLE>
sounds like it was having issues before and after. i hardly doubt an ignition would fry your piston rings.
Old Nov 7, 2003 | 02:14 PM
[ iLL ] iNt3GrA's Avatar
how much oil is it burning?
Old Nov 7, 2003 | 03:26 PM
Default Re: ([ iLL ] iNt3GrA)
abour 3/4 of a qt every 2 weeks
Old Nov 7, 2003 | 03:28 PM
Default Re: burning oil (svtec)
it wasn't burning oil before the install of the msd i immediately smelled the burning
Old Nov 7, 2003 | 06:48 PM
mel_2kgsr's Avatar
i think that you may be running lean and therefor engine is getting hotter and thus burning more oil. Oil breaksdown at different temps and i am only guessing that maybe high temps are doing it.
Old Nov 7, 2003 | 06:50 PM
King_j's Avatar
Default Re: burning oil (mel)
were you racing before/after the install?
Old Nov 8, 2003 | 03:22 AM
Default Re: burning oil (King_j)
not really racing but i drive it hard sometimes
Old Nov 8, 2003 | 05:39 AM
King_j's Avatar
ignition has nothing to do with oil. are you sure is burning and not leaking?
if so, do a compression test.
btw: when was the last ime you did a valve adjustment?
Old Nov 8, 2003 | 08:57 AM
we are going to to the compression test today and i havent had a valve adjustment yet
Hiroshima_VTi-S
Aug 23, 2006 12:12 PM
Acura-integra_101
Nov 13, 2005 01:34 PM
98cwitr
Apr 27, 2004 01:34 PM
TRH
Jan 26, 2004 06:33 PM
wm5holla
May 19, 2003 07:30 PM
