WHAT happenswhen u burn oil?
Old May 18, 2003 | 10:31 AM
wm5holla's Avatar
Default WHAT happenswhen u burn oil?
well what happens when ya burn it
Old May 18, 2003 | 12:36 PM
MikeSarr_GSR's Avatar
Default Re: WHAT happenswhen u burn oil? (wm5holla)
it disappears.
Old May 18, 2003 | 01:58 PM
4DeepCivic's Avatar
Default Re: WHAT happenswhen u burn oil? (MikeSarr_GSR)
Your plugs foul, you may get a new feature on ur car... called smoke screen. hmmm..what else.. you have less oil in the engine.
Causes... bad head gasket, bad rings and seals.. that's all i can remember.. maybe someone else can help u
Old May 18, 2003 | 03:16 PM
deepnite's Avatar
Default Re: WHAT happenswhen u burn oil? (4DeepCivic)
heat will burn oil..no matter what u do..ive found that using a syn. oil like Mobil 1 will lessen the loss of oil due to oil burn off
Old May 19, 2003 | 07:30 PM
Default Re: WHAT happenswhen u burn oil? (deepnite)
wether it escapes through the seals, rings or gaskets, losing oil is losing oil.
it drains your wallet
CroSi
Aug 14, 2003 04:32 PM
Pinpid
Dec 17, 2002 04:55 PM
deepnite
Oct 9, 2002 01:46 PM
CivicBoi
May 27, 2002 11:59 AM
