Crap, I put too much oil in my car
Old Sep 8, 2001 | 01:34 PM
DrewGSR's Avatar
Default Crap, I put too much oil in my car
Ok, you know how theres the two dots, i have double that amount, i wasn't paying attention and i only meant to put in 1/3 of the bottle, and ended up putting all of it. Now i have a crap load in there. Is that really bad for the car? If so should i take some out or is it ok to leave it there?
Old Sep 8, 2001 | 02:54 PM
Dr Pooface's Avatar
Default Re: Crap, I put too much oil in my car (DrewGSR)
Drain a little out if your worried.
Old Sep 8, 2001 | 03:58 PM
HXMan's Avatar
Just drain it out into a clean container...and put what you need back in.
That is what I would do....but I use Mobile 1...and that goes for about $4.50 per quart.
If you use regular you could just buy some more, and recycle the stuff you take out.
Old Sep 8, 2001 | 04:54 PM
flymecourageously's Avatar
New User
drain it immediately to the appropriate level imagine the extra pressure in there its going to have to give some where maybe a leak through a gasket or mes up the valve train
Old Sep 8, 2001 | 05:06 PM
Blown90hatcH's Avatar
Default Re: Crap, I put too much oil in my car (flymecourageously)
Its not going to mess up the valve train....But why do you think that there is a limit? If you run too much oil pressure, you will cause extreme pressures on your oil rings and ultimately result in blow by like a beeaaatch.
J
Old Sep 9, 2001 | 05:21 PM
Mr. Choi's Avatar
New User
Default Re: Crap, I put too much oil in my car (Blown90hatcH)
yes he is right, you know your stuff, good!
Old Sep 9, 2001 | 08:01 PM
fixhondas's Avatar
Default Re: Crap, I put too much oil in my car (Chois i-VTEC)
Having too much oil will NOT increase oil pressure. It can decrease pressure- Too much oil can be whipped up by the crankshaft resulting in "foamy" oil which reduces oil pressure.
Old Sep 10, 2001 | 04:05 AM
hondachick81's Avatar
Default Re: Crap, I put too much oil in my car (fixhondas)
You need to change it out and put the right amount of oil in.
If you put to much in, you will blow a gasket.
Old Sep 10, 2001 | 09:50 AM
smokin rubber's Avatar
Default Re: Crap, I put too much oil in my car (CivicGirl114)
yep civicgirl knows from my experience, It is better to drain some oil now than to do another oil change in two days when you blow your oil pan gasket.
Old Sep 10, 2001 | 12:27 PM
donkeypunch's Avatar
Default Re: Crap, I put too much oil in my car (smokin rubber)
As long as it is not coming out the vents...you are fine. j/k
Old Sep 10, 2001 | 12:45 PM
hey you!!!! I saw you today on the road....guess you were going to work!!
Nopi........5 more days!!!! woooohoooooo
Old Sep 10, 2001 | 01:19 PM
gsxr for yo momma's Avatar
New User
go find a street with a speed bump in the middle of it. Speed towards it and when you slam into it and bottom out your oil pan, the resulting hole will get rid of your excess oil.
Old Sep 11, 2001 | 05:28 AM
drift's Avatar
New User
the motor is ruined... sell the car.
Old Sep 11, 2001 | 08:30 PM
New User
thats what i meant it's not good . could put to much pressure and blow your tires out : : :
Old Sep 12, 2001 | 08:40 AM
I say go for the speed bump thing....that should get rid of the extra oil..
fixhonda-Too mcu oil will not increase your oil pressure??? Think about it....Oil pressure low = not enough oil....Oil pressure = too much oil....It isnt that hard to figure out...just common sense...
Ryan_v
Jul 14, 2009 03:41 PM
88 EF Hatch
Jun 7, 2009 10:32 PM
SolAssassin
Oct 19, 2007 11:57 AM
Boostless97Lude
Feb 3, 2003 02:06 PM
synergy004
Jul 7, 2002 01:25 AM
