WTB: nylon tubing for boost gauge
Old Nov 5, 2003 | 08:13 AM
JDubya's Avatar
Default WTB: nylon tubing for boost gauge
I went to Autozone and looked for it like someone recomended, but they didn't have it. Anybody have some to sell? Do they make a type of fitting for this nylon tubing that allows you to T into a rubber line? and also, does the tubing just push into the brass fittin on the back of the gauge or do you have to unscrew it first or something? I bought the gauge used, so I'm not exactly sure...
Old Nov 5, 2003 | 08:31 AM
egturbo's Avatar
Default Re: WTB: nylon tubing for boost gauge (ALL MOTOR LS)
i just used some tubing and twisted it onto the fitting on the guage.. very easy mod.. works very well also.. i used rubber tubing small... hope that helps
Old Nov 5, 2003 | 09:10 AM
hulkhb's Avatar
Check Schucks/Kragen/Checkers, whatever its called where you live. They have it, its behind the counter, ask em.
Old Nov 5, 2003 | 11:49 AM
JDubya's Avatar
Default Re: WTB: nylon tubing for boost gauge (hulkhb)
Too bad there's none of them around me... Do you know how much it cost's? B/c I think Autometer sells a kit w/the tubing and a fitting for like $10. So is there a GOOD way to connect the nylon tubing to a rubber vacuum line?
Old Nov 5, 2003 | 06:10 PM
Vtec92Civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALL MOTOR LS &raquo;</TD></TR><TR><TD CLASS="quote">I went to Autozone and looked for it like someone recomended, but they didn't have it. Anybody have some to sell? Do they make a type of fitting for this nylon tubing that allows you to T into a rubber line? and also, does the tubing just push into the brass fittin on the back of the gauge or do you have to unscrew it first or something? I bought the gauge used, so I'm not exactly sure...</TD></TR></TABLE>
i'm gona be a life saver . . . if you have an autometer gauge go and get a barb fitting from any hardware store only about $1.50, you screw that onto the back of the gauge, and go and get vacuum line from any autostore for about 0.35 a foot figure you spend mybe $3.00 on that, and that's all you need.
THat is exactly what me and all my friends did, and it works perfect! That nylon tubing that comes with the gauge is crap
Old Nov 5, 2003 | 07:45 PM
b18c4door's Avatar
Exactly what vtec92civic says, those plastic lines are a POS in my opinion, vaccum hose is much better than that plastic crap. I found the fitting I needed at a NAPA...
Old Nov 6, 2003 | 04:05 AM
JDubya's Avatar
Default Re: (b18c4door)
What thread pitch (or whatever it's called) do I need?
Old Nov 6, 2003 | 04:16 AM
JDubya's Avatar
Default Re: (ALL MOTOR LS)
and what mm. tubing should I get, 4? 6?
Old Nov 6, 2003 | 08:11 AM
kamaleon's Avatar
i find the plastic line to be better than the rubber ones.. rubber can expand and the plastic one wont. if ur doign low psi ull be fine with the rubber one, higher psi might cause the rubber to expand.
anyways, PepBoys has a kit that cost arround $6 fittings, tubing and brass thingis
Old Nov 10, 2003 | 02:02 PM
JDubya's Avatar
Default Re: (kamaleon)
I still can't find anything to make it work. I went to autozone to look for a barbed fitting, no go. I went to pep boys to look for the kit w/the plastic tubing, no go. What should i do? for 10psi will the rubber line work or will it expand too much?
Old Nov 11, 2003 | 04:08 AM
JDubya's Avatar
Old Nov 11, 2003 | 05:29 AM
underpressure02's Avatar
I kinked my plastic line and needed to get some new stuff. I found mine at A&A but it was like 12 bucks for the pack and it included two fittings and like 10 feet of line. If you still can not find it. I can drive and buy it for you if you want to pay the shipping.
Old Nov 12, 2003 | 09:51 AM
JDubya's Avatar
Default Re: (underpressure02)
Hmm, how much is the SUNPRO kit that some Autozone's sell? the one near me doesn't have it. Anyone know?
Old Nov 12, 2003 | 03:02 PM
that is what I bought the sunpro stuff. I belive it was 12 bucks.
Old Nov 13, 2003 | 05:18 PM
hooohaa2's Avatar
I just saw the sunpro kit in my autozone for like $6.50.
Old Nov 13, 2003 | 05:26 PM
TeStUdO's Avatar
Try this instead
http://www.scoobymods.com/foru...gauge
Old Nov 13, 2003 | 05:32 PM
Turbo'dMex-A-Keen's Avatar
Default Re: (TeStUdO)
or u can just go to Home De-Pot and get some clear tubing, thats what im using
Old Nov 13, 2003 | 06:25 PM
hooohaa2's Avatar
I like the trick on scoobymods, i think i will try it
Old Nov 13, 2003 | 07:02 PM
TeStUdO's Avatar
Default Re: (hooohaa2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hooohaa2 &raquo;</TD></TR><TR><TD CLASS="quote">I like the trick on scoobymods, i think i will try it</TD></TR></TABLE>
Yeah the gauge will be more accurate
Old Nov 13, 2003 | 09:37 PM
Jkan2001's Avatar
autozone sells the complete nylon tubing kit with the brass fitting that goes into the back of autometer boost gauges. I was there the other day and my friend got pissed cause he spent forever hunting down a kit and they had it hanging right there
Old Nov 14, 2003 | 06:26 AM
JDubya's Avatar
To do the scoobymods way, do I NEED to get a barbed fitting, or could i just put the hose over the threads and use a hose clamp? I'm not talking about the big threaded piece that comes out of the gauge, but the first brass fitting that screws onto that, it reduces the thread size, would that be ok, or do you recomend a barbed fitting?
R6E6I6D
Nov 21, 2005 06:47 PM
AlphaQup
Oct 24, 2005 06:38 PM
blackeg
Jun 17, 2004 06:46 AM
B18EG6
Aug 7, 2002 12:31 PM
