can't adjust lights
Old Nov 4, 2003 | 06:07 PM
pootie.teng's Avatar
Default can't adjust lights
yo anyone knows why i can't adjust my front head lights? my left lamp is shining too high. i got a 97 civic hatch...
Old Nov 4, 2003 | 06:13 PM
HXvtec's Avatar
Default Re: can't adjust lights (teckno_geek)
i have the same problem. take them out and there should be a 10mm screw that adjusts the lamp. but make sure its level. check the level by looking between the headlight there a balancer thing. (not sure what its called) thats how u adust them.
Old Nov 4, 2003 | 06:21 PM
Default Re: can't adjust lights (HXvtec)
so i do need to take out the whole head lamp. or is it reachable with it still on the car.
Old Nov 4, 2003 | 06:34 PM
HXvtec's Avatar
i had to take the whole thing out. it wasnt reachable for me.
Old Nov 4, 2003 | 06:37 PM
Philip's Avatar
don't take it out. look in the manual and it explains how to insert a screw driver a certain way to adjust the headlights.
you insert the screw driver from the top, then turn the little gear thingie, you don't mess with the 10mm bolt.
Old Nov 4, 2003 | 06:39 PM
HXvtec's Avatar
Default Re: can't adjust lights (Philip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Philip &raquo;</TD></TR><TR><TD CLASS="quote">don't take it out. look in the manual and it explains how to insert a screw driver a certain way to adjust the headlights.
you insert the screw driver from the top, then turn the little gear thingie, you don't mess with the 10mm bolt.</TD></TR></TABLE>
thats probably why my lights are screwed.
Old Nov 4, 2003 | 06:40 PM
pdiggitydogg's Avatar
^right
the adjuster works like a spider gear
Old Nov 4, 2003 | 06:46 PM
HXvtec's Avatar
Default Re: (pdiggitydogg)
i lost my book. where is this thing ur talking about.
Old Nov 4, 2003 | 06:49 PM
go out and look
its brass colored and about 2cm across .5cm thick
put the screwdriver (phillips) between the gears and turn it
HXvtec's Avatar
ok brb
Philip's Avatar
Default Re: (HXvtec)
I think the bolt/nut thing is connected to the gear. well, you insert the screwdriver from the top right above the gear thing. you have to insert at a diagnol, then the screwdriver fits into the gear, you turn the screwdriver, (turning the gear) and your lights are adjusted
Old Nov 4, 2003 | 06:51 PM
reading the manual is also a good thing, since it has a picture
Old Nov 4, 2003 | 06:52 PM
Philip's Avatar
oh yea, how do you lose an owner manual? i thought everyone just kept in the glove box...
edit: wasn't being rude, just wondering cuz i know others that have lost their manuals
Old Nov 4, 2003 | 06:54 PM
D16Z6's Avatar
Default Re: (Philip)
sometimes.. they grow legs and walk out....
Old Nov 4, 2003 | 07:01 PM
HXvtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Philip &raquo;</TD></TR><TR><TD CLASS="quote">oh yea, how do you lose an owner manual? i thought everyone just kept in the glove box...
edit: wasn't being rude, just wondering cuz i know others that have lost their manuals</TD></TR></TABLE>
i lose everything
Old Nov 4, 2003 | 07:02 PM
HXvtec's Avatar
its somewhere around here n e way my lights are screwed. i know what u guys are talking about. i kept turning the gear and nothing happened. i need to stop messin around with my car.
Old Nov 5, 2003 | 07:53 AM
there are 2 adjusters
one is vertical
one is horizontal
Old Nov 5, 2003 | 07:57 AM
6SPD_EK's Avatar
the one closest towards the side of the car adjusts up & down - the one towards the center (grill) adjusts horizontally I believe
search results
https://honda-tech.com/zerothread?id=597861
Old Nov 6, 2003 | 11:27 AM
hey for reals i keep on turning that darn thingy magigy screwwy but still nothing happens. i don't know what the f@*k is going on with that head light. i turn that screw over and over in every direction but still the head light said, "not by the hair on my chinny chin chin." i'm about to junk the light if i can't fix it. it seems to be blinding everyone...
Old Nov 6, 2003 | 11:43 AM
which one are you turning
(Oh, and counter clock-wise is up, clock-wise is down)
Old Nov 6, 2003 | 12:02 PM
i'm turning the verticle one. to make it shine lower so it doesn't blind anyone. but nothing is happening. i can see the little teeth thingy truning but the light won't shine lower. this sucks.
Old Nov 6, 2003 | 01:52 PM
keep turning...it will move
takes more than a 1/4 turn...takes a lot
FiresII
Oct 13, 2013 04:42 AM
mario_pic
Dec 18, 2007 04:14 PM
. M i c h a e l
Jul 11, 2006 05:08 PM
DIRep972
Nov 18, 2001 05:17 PM
Blue teg
Nov 13, 2001 07:55 AM
