Coolant leaking, but i cant tell from where.
Old Nov 4, 2003 | 02:41 PM
vtecdc2's Avatar
Default Coolant leaking, but i cant tell from where.
my roommate found a small puddle of coolant under my car today, but i cant tell where its coming from. it appears to be dripping off the oil pan, but it doesnt make sense there. i dont see any visable leakage from the head gasket. any ideas?
Old Nov 4, 2003 | 02:50 PM
KRiS1's Avatar
Default Re: Coolant leaking, but i cant tell from where. (VTECDC2)
Thats a tough one with so little info. Clean your engine bay then drive around and check to see if it squirted coolant anywhere. How much does it leak?
RCautoworks's Avatar
There are some coolant hoses behind and under the intake mani, probably one of those.
Old Nov 4, 2003 | 03:11 PM
Jay J's Avatar
Prince of Zamunda
Default Re: Coolant leaking, but i cant tell from where. (90blackcrx)
Try adding that coolant additive/ leak additive where it makes the leaking spots show with florescent light
Old Nov 4, 2003 | 03:20 PM
rob d's Avatar
Default Re: Coolant leaking, but i cant tell from where. (neuspeed)
It might be the water pump. What side is it leaking from? Pulley? How many miles?
Old Nov 4, 2003 | 03:27 PM
HATCHingMN's Avatar
Default Re: Coolant leaking, but i cant tell from where. (rob d)
Have you check the lower radiator hose and the Low or bottom part of the radiator??
Old Nov 4, 2003 | 06:16 PM
vtecdc2's Avatar
Default Re: Coolant leaking, but i cant tell from where. (HATCHingMN)
i already checked the radiator. its fine. it appears as if its coming from the block somewhere. i'll check the water pump..
Old Nov 4, 2003 | 06:22 PM
Tomek's Avatar
Its most likely your waterpump imo.
Old Nov 4, 2003 | 06:43 PM
Frozen E's Avatar
H-T White Ops
Hmmmm, if you're looking at the actualy engine and can't tell where it's leaking from, how do you expect people that can do nothing more than see WORDS to know where it's leaking? Just an observation I made here.
There are sooooo many places you could get coolant leaks from. Take it to a shop if you can't find it.
Old Nov 4, 2003 | 06:44 PM
vtecdc2's Avatar
Default Re: (FrozenSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FrozenSi &raquo;</TD></TR><TR><TD CLASS="quote">Hmmmm, if you're looking at the actualy engine and can't tell where it's leaking from, how do you expect people that can do nothing more than see WORDS to know where it's leaking? Just an observation I made here.
There are sooooo many places you could get coolant leaks from. Take it to a shop if you can't find it.</TD></TR></TABLE>
i just asked for ideas, not actual answers.
WeakSauce92
Aug 25, 2010 12:57 PM
SeanK325
Jun 22, 2010 02:52 PM
donald810714
12
Feb 6, 2010 04:12 PM
turbohb21
Sep 24, 2007 11:36 PM
redsled00
Jan 22, 2003 07:40 AM
