Axle popped out while suspension install
Old Nov 1, 2003 | 06:52 PM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Axle popped out while suspension install
what to do
i didn't even realizxe it till when i test drove it, the car started making weird noise and i knew my axle had popped out
Old Nov 1, 2003 | 06:57 PM
Xgen's Avatar
Default Re: Axle popped out while suspension install (MugenHonda)
make sure its ok, make sure your CV boot dosnt have a tear in it and put it back in.
Old Nov 1, 2003 | 09:39 PM
kid-honda's Avatar
Make sure nothing is wrong with the axle( cracked, tore a boot, shreded the teeth) Then replace the c clip that holds the axle in the tranny/intermediate shaft(depending on motor) a faulty c clip is probly why it fell out.
Old Nov 1, 2003 | 09:50 PM
Ef Whore's Avatar
Default Re: (kid-honda)
How you didn't notice your axle not being in when you were reinstalling the susp. is beyond me. You should always do a final check to all the susp./driveline points before putting it in the ground and driving it. You better hope that C-clip did'nt fall off inside the differential or else that trans could be toast!
Old Nov 2, 2003 | 01:14 AM
MugenHonda's Avatar
Default Re: (Ef *****)
My stupidity, as I move the wheel all around
lol
Pwnmeister
Jun 25, 2013 07:55 AM
jmurphy
17
Apr 5, 2011 01:19 PM
Cuong-nutz
16
Apr 17, 2005 08:50 AM
GSpeedR
Aug 11, 2002 03:06 PM
