Stahl's at stop
I have a 95 civic with Greddy turbo, my car idles low then turns off at a stop...sparatically not everytime or even everyday. If I turn my AC on the extra belt raises my RPM's and my car will stay on. Any ideas what it could be. Thanks guys.
Stahl's went out of business??????
http://www.stahlheaders.com/
I hope not, I need custom bent tubing!!!!!!!
I've got greddy turbo and I was having an idle problem where it would try to idle at 300-400 rpm. I had to drive with my headlights on to bump my idle up. It was an easy fix for me. I just screwed the bypass screw on the TB out 3/4 of a turn. I think it lets more air past the TB so the IACV doesn't have to work so hard when I come off throttle to modulate idle. My problem was mainly when I was coming off-throttle, or if I blipped the throttle after my car was fully warmed up the idle would drop way low and stay there for a second until the ecu idled it back up. Hope that helps.
Car Tweaker
Sep 13, 2009 08:28 PM
headhunter
Aug 18, 2003 08:14 PM
