check engine CODE 67 - defective catalyst system???
Old Oct 30, 2003 | 01:35 PM
smooz EK's Avatar
Default check engine CODE 67 - defective catalyst system???
sup fellas,
my check engine light was on for over a month and i finally decided to check it. it came out 67 - Catalyst system Efficiency Below Threshold malfunctioning or defective catalyst system.
wtf does this mean? what do i need to do?
thanks for the help.
Old Oct 30, 2003 | 03:43 PM
smooz EK's Avatar
Default Re: check engine CODE 67 - defective catalyst system??? (smooz EK)
no one has had this problem?
Old Oct 30, 2003 | 04:03 PM
xhatchracerx's Avatar
are u running a aftermarket cat? if so its probably defective in other words its dead. Nothing beats OEM honda
Old Oct 30, 2003 | 04:21 PM
Ricey McRicerton's Avatar
Default Re: check engine CODE 67 - defective catalyst system??? (xhatchracerx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xhatchracerx &raquo;</TD></TR><TR><TD CLASS="quote">are u running a aftermarket cat? if so its probably defective in other words its dead. Nothing beats OEM honda</TD></TR></TABLE>
I don't agree. I think this could be a problem with your secondary 02 sensor of you catalytic converter is clogged. You can pull it off and check to see if it is clogged or you can just spring for a new Catco or similar. They won't be more than 100 bucks and are better than OEM ones (if you are modified at all).
Old Oct 31, 2003 | 12:18 AM
smooz EK's Avatar
Default Re: check engine CODE 67 - defective catalyst system??? (Ricey McRicerton)
well, my car is bone stock except its lowered with rims.
but i will check the cat is clogged. thanks for the info.
Old Oct 31, 2003 | 06:01 AM
quanek4's Avatar
make sure theres nothing making the second O2 sensor **** up....if thats straight then its the cat
Old Jan 1, 2004 | 01:08 AM
sparxx's Avatar
I'm getting the same code...and I'm getting a 68...which I can't even find text on.
are your wires shielded correctly?When did the problem start?have you install anything or unplug/replace/fix any wires recently?
Old Jan 6, 2004 | 02:54 AM
sparxx's Avatar
Default Re: check engine CODE 67 - defective catalyst system??? (sparxx)
had same problem...are you getting any other cels?if not try to get them...unplug a sensor at a time.....make sure after pulling each one you check cel code to confirm the ecu is registering sensor as unplugged and especially check to see if the right code comes up for right sensor....example: if you unplugg your knock sensor and iat fails, or vice versa or anything like that then you have allmost found your problem....also check to be sure that all sensors have the correct number of wires going into them...thermistors=2 TPS=3(i think w/o looking.check repair manual for specific number of wires and wire colors.)knock sensor=1 so on and so forth.
hope this helps and if not then search around some more and learn more about your electronic components under the hood
si937
May 7, 2008 11:18 PM
kkwick
Apr 30, 2008 09:30 PM
MugenDC4
Mar 7, 2007 12:31 AM
bma1818
Apr 19, 2006 09:55 PM
Mires
Jul 3, 2003 07:37 AM
