>Please Help with Check Engine Light Code 67 Cat Converter
My sister 99' civic LX pop up an check engine light. When I jump the connector, it gave me a code 67 which is the Catalytic converter https://honda-tech.com/zerothread/1901557. When I recall, the stock headers which had the cat converter built with it. I replaced it a few months ago with an aftermarket OEM style which came in two pieces (headers/cat convertor). A couples months passed after the replacement, that is when the check engine light pop up. My question is, how can I tell if the cat converter is bad? Any help would be appreciated
Re: >Please Help with Check Engine Light Code 67 Cat Converter (95DxSi-R2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95DxSi-R2 »</TD></TR><TR><TD CLASS="quote">do a system monitor catalytic converter test. </TD></TR></TABLE>
sorry for being a noob, but how do you do that?
Guest
Posts: n/a
Re: >Please Help with Check Engine Light Code 67 Cat Converter (MugenDC4)
u can't do it unless u have a scan tool, most likely it's your cat thats bad. The pcm monitors up and downstream o2's to see if the cat is converting the gasses. and yours is not.
