HOW MUCH transmission fluid in h22 tranny???
Old Oct 30, 2003 | 12:36 PM
gaydm.accord's Avatar
Default HOW MUCH transmission fluid in h22 tranny???
as topic says, i did search but nothing on h22 just want to know if its different and i want to do it today dont know how its gonna turn out first time but i know where to aim at but how much and when to stop is the issue what if i put too much?? is too much bad??
and what fluid should i go with ???
Old Oct 30, 2003 | 12:50 PM
Muckman's Avatar
Moderator in Chief
Default Re: HOW MUCH transmission fluid in h22 tranny??? (gaydm.accord)
Your going to need a little more than 2 quarts, so buy 3. Honda MTF is what the Helms recommends, alot of ppl including myself use GM Synchromesh MTF (do a search for more info).
You cant over fill it because the drain plug is vertical, on the side of the tranny. And you fill it until it comes out the drain plug.
I also recommend that you pick up a gear oil pump so you can fill it up, since the drain plug is on the side.
5th Gen Prelude Helms, Transmission Section
Old Oct 30, 2003 | 01:02 PM
KW2000's Avatar
Default Re: HOW MUCH transmission fluid in h22 tranny??? (Muckman)
i believe helms says 1.9 ....its pretty ez on the mt tranny just filll it up till it starts to pour outa the fill hole u can't over fill it
Old Oct 30, 2003 | 01:19 PM
thanks guys
Old Oct 31, 2003 | 01:19 PM
tried to find the GM Synchromesh MTF but all they had was some other gear oil where can i get this GM Synchromesh MTF
Old Nov 1, 2003 | 03:40 PM
bump
Old Nov 1, 2003 | 07:57 PM
rob d's Avatar
Default Re: (gaydm.accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gaydm.accord &raquo;</TD></TR><TR><TD CLASS="quote">tried to find the GM Synchromesh MTF but all they had was some other gear oil where can i get this GM Synchromesh MTF </TD></TR></TABLE>
GM/Chevy dealer. Get the GM synchromesh friction modified. Part # 12377916 Its about $11. I hade a slight 5th gear grind and it went away when I used this oil.
Old Nov 1, 2003 | 07:58 PM
Muckman's Avatar
Moderator in Chief
Its been discussed up and down a million times, thats why i said to search.
https://honda-tech.com/zerothread?id=549469
Old Nov 1, 2003 | 10:05 PM
sorry my bad i was in a rush fixing my other problem with my tie rod didnt have time to search but now i got free time ima do a search now thanks
Adrian G. Aka JDMonkey
Oct 18, 2006 04:17 PM
T"u"Rtle
Feb 27, 2006 11:39 PM
r1de4life
Jan 3, 2006 05:36 PM
pelotudo
Jul 21, 2002 02:33 AM
96Prelord
Jun 5, 2002 07:21 PM
