How many qts should a H22 tranny have of tranny fluid??
Quite simply stated how many quarts does the H22 tranny need for tranny fluid. I had only put in two quarts is that enough??
Re: How many qts should a H22 tranny have of tranny fluid?? (H22Hatchie)
Best thing i found to do was to pull the drain plug and make sure that the car is on level ground, pull the VSS out and then fill with funnel from there and when it starts coming out of the drain plug on side that should be plenty i believe i put around three in mine when i dropped it in my hatch
