Can i use a cable tranny in a 92 Hatchback?
Old Oct 30, 2003 | 11:20 AM
WhoNeedsBoost's Avatar
Default Can i use a cable tranny in a 92 Hatchback?
i know they are hydrulic.. but hasport says i can use it.. but id rather go by what you people say... id rather use a first gen B16 then a second gen.. (alot cheaper) open to oppion..
Old Oct 30, 2003 | 11:23 AM
92civeg's Avatar
Default Re: Can i use a cable tranny in a 92 Hatchback? (WhoNeedsBoost)
you can use a cable but id stick with a hydrolic
Old Oct 30, 2003 | 11:37 AM
Default Re: Can i use a cable tranny in a 92 Hatchback? (92civeg)
Why would you stick with the hydrolic?
and whats needed to use a cable tranny?
SloCivicHMM's Avatar
sure you can use a cable....just need the pedal assembly and run the cable....I've actually thought about this for my ZC...but who knows...haha
Old Oct 30, 2003 | 03:10 PM
Default Re: Can i use a cable tranny in a 92 Hatchback? (SloCivicHMM)
isnt there an adapter i can use?
Old Oct 30, 2003 | 09:19 PM
anyone?
Old Oct 30, 2003 | 10:30 PM
EG(6)SR's Avatar
yes there are adaptors that you can buy. I believe that the kit includes the braket, and the tranny mount. (due to the tranny mount being different in sub 92 civics.) You should be able to find it quite easily.
But oh, last time I can remember, they were in the area of 200 or more dollars, so you have to wonder about the money your saving useing a cable could go out the door with the kit. For me personally, i found the price of the cable+conversion about the same as just buying a hydrolic one. So my advice is just to save up and get the hydro, unless that particular cable one has goodies like lsd and/or final drive. goodluck
Old Nov 1, 2003 | 03:17 PM
zer0.'s Avatar
try http://www.hybridgarage.com i have a cable tranny on my LS.....but i suggest a hydro tranny.
Old Nov 1, 2003 | 03:29 PM
2000blackgsr's Avatar
Default Re: (zer0_2_6ixty)
I think HaSport makes a conversion kit as well. I could be wrong, just a thought.
Old Nov 1, 2003 | 03:52 PM
Looose_R's Avatar
Default Re: (96coupe)
yes, hasport offers a hydro-cable adapter. benefit of the hydro is that its not going to be more than 10years old like all the cable trannys out there. they seem to all have grinds and no one rebuilds them for one reason or another
Old Nov 1, 2003 | 04:12 PM
Cynical 1's Avatar
Of course Hasport says you can use it. They want your money, by selling you the kit to do it...
Stay hydro, Honda went to it for a reason...
Old Nov 1, 2003 | 05:03 PM
flat-blk-HB's Avatar
Default Re: Can i use a cable tranny in a 92 Hatchback? (Revolveu2)
I am using the Hydro to cable conversion in my 92 Civic CX...I am using a S1 cable tranny with my LS/vtec...It comes with the tranny mount, new pin type thing for the slave cylinder....You keep all your old hydro **** but the slave cylinder just pushes the throw out bearing fork or whatever you want to call it..my reasoning behind going cable it they are cheaper and more plentiful for me to find....the both feel the same with this conversion and I beileve there is more choices to choose from with the cable trannies...
HASport kit BTW..
just my .02
type_one1
Oct 3, 2005 04:51 AM
allmota1.8
Feb 7, 2004 04:20 PM
USDMMARK
May 22, 2003 11:45 AM
88crxdx
Mar 15, 2003 01:57 AM
AfEn808
Jan 16, 2002 11:20 PM
