What did I do...?
Old Oct 29, 2003 | 03:00 PM
Gonzo_SiR's Avatar
Default What did I do...?
I was hooking up my new Proform Shift Light. Here's what I did...
1)hooked up red wire to the positive Batt. terminal
2)hooked up black wire to the negative Batt. terminal
3)hooked up the tach wire to the blue wire out of the Distributor.
4) I tried to turn on the car but it's completely DEAD.
Did I screw up my Distributor..? Any help would be appreciated.
Old Oct 29, 2003 | 06:35 PM
Hybridize's Avatar
How did you hook up your tach wire? Thats the only wire you touched that could cause a problem...
Does the car run when you remove the tach wire you hooked up?
Old Oct 29, 2003 | 07:38 PM
Gonzo_SiR's Avatar
Default Re: (Hybridize)
I hooked it up to the blue wire on the distributor, because that's what the instructions said to do... where in WA are you...?
Old Oct 29, 2003 | 10:12 PM
Kazz's Avatar
Default Re: (Gonzo_SiR)
i don't know what you didi but i know that blue wire can go to the back of your gauge cluster.. that controls the rpm.. it should be a blue and white wire...
Mac Listo
Apr 22, 2008 06:03 PM
valentine97
Jan 18, 2008 09:36 AM
slimjimdanny
Jan 31, 2007 07:35 PM
97grnrs
Jan 11, 2006 07:32 PM
civicracer1993
Sep 17, 2002 10:53 PM
