H23-->H22 Injector help
Old Oct 28, 2003 | 10:49 PM
Gerst240's Avatar
Default H23-->H22 Injector help
I am currently helping a friend put a h22 into his 92 prelude that came with a h23. We have the h22 currently in the engine bay and waiting to be wired up. Today when i was test fitting wires to see what needs extended or what needs to be switched over i found that the h22 injectors have a different connector than the h23. So heres my question can i just cut the injector wires and solder the h22 wires on (we have a h22 harness just sitting there)will that work fine or is there another solution that other people use?
thanks
erik
Old Oct 29, 2003 | 04:47 AM
CHK4TIX's Avatar
Default Re: H23-->H22 Injector help (Gerst240)
ok i have a few question, what year h22 did you use? Is the h22 harness on the engine or did you re-use the h23 harness? If you are using the h23 harness and the engine the clips might look a little different but they will clip right up. I did not have to cut any wires or make any adjustments to the harness besides the vtec wires. If your engine is an obdII engine then it might be a little different. also if you need the pins for the ecu for the vtec wires let me know. i have them
Old Oct 29, 2003 | 04:51 AM
Gerst240's Avatar
We resused the h23 wiring harness, the engine is a 95 obd1. The injector wires are differrent they will not fit on the h22 injectors. It looks like if we shaved a little plastic off the injector plugs it would work but how it is now there is no way in hell theyre fitting. Im starting to wonder if i should just plug the h22 harness in and go from there. What do you guys think?
Old Oct 29, 2003 | 05:16 AM
CHK4TIX's Avatar
Default Re: (Gerst240)
well, if you have a full H22 harness already then just use that, but i don't see how the injectors clips would be different unless your 95 h22 odbI is actually for a 96 lude which would be obdII. Is the engine JDM or USDM? if its JDM did it come with the partial harness? if so see if there is the wiring to goto the resister box that is located on the drivers side of the engine compartment by where you put clutch and brake fluid
Old Oct 29, 2003 | 06:05 AM
noble4ws's Avatar
im his friend, the engine is a usdm h22a
Old Oct 29, 2003 | 06:13 PM
noble4ws's Avatar
ttt, any other advice on the injector plugs
Old Oct 29, 2003 | 07:26 PM
CHK4TIX's Avatar
Default Re: (noble4ws)
well, im confused at why they would be different, i say try posting in the prelude forum, maybe one of those guys had the same issues
Old Oct 29, 2003 | 07:36 PM
noble4ws's Avatar
thanks alot man, i appreciate all your help, btw how much you charge for those pins
Old Oct 29, 2003 | 08:50 PM
Gerst240's Avatar
Well we found the problem the wiring harness that came with the engine is hacked and looks like dsm injectors not sure but they arent stock.....ill try to post a pic tomorrow
Modified by Gerst240 at 10:13 PM 10/29/2003
Old Oct 29, 2003 | 09:57 PM
noble4ws's Avatar
please see post in tech forum https://honda-tech.com/zerothread?id=663443
Old Oct 30, 2003 | 06:44 AM
CHK4TIX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gerst240 &raquo;</TD></TR><TR><TD CLASS="quote">Well we found the problem the wiring harness that came with the engine is hacked and looks like dsm injectors not sure but they arent stock.....ill try to post a pic tomorrow
Modified by Gerst240 at 10:13 PM 10/29/2003</TD></TR></TABLE>
well, if thats the case you have a few options, you can locate stock h22 injectors and use the h23 harness or redo the wiring and use a vafc to adjust for the larger injectors. If you are planing on just going all motor it would probably be better to get stock injectors.
Old Oct 30, 2003 | 06:59 AM
noble4ws's Avatar
would it be alright to run the h23 injectors, or would that just make it run lean, btw they arent dsm they are honda injectors just dont know from where https://honda-tech.com/zerothread?id=663443
Old Oct 30, 2003 | 07:32 AM
CHK4TIX's Avatar
it would run way to lean using h23 injectors. expecially if you accidently hit vtec.
Old Oct 30, 2003 | 11:25 AM
noble4ws's Avatar
i would rewire the harness but i have no idea what size those injectors and i cant afford a vafc right now and it would be useless since i dont know what size the injectors are, looks like i will have to find some stock injectors
wolfpackprelude
Sep 28, 2006 06:26 PM
darockstar
Mar 4, 2006 09:22 PM
Aaran
Jul 27, 2005 10:56 PM
jakeiscool
Mar 17, 2005 12:37 PM
snake679
Jun 16, 2003 12:17 PM
