car smokes after sitting
Old Oct 28, 2003 | 07:14 PM
nevin's Avatar
Default car smokes after sitting
as stated the car smokes alot of oil after sitting in the morning. This is the valve seals dripping oil down into the cylinders overnight, not the rings right? once it warms up after a minuite or 2 the smoke goes away. It does smoke a litte at wot i think, but its really black/blue and I know im running rich as hell so I don't know if oil is involved with that. but in the morning it smokes ALOT so im guessing valve seals and I could use a valve adjustment also probly.
Old Oct 29, 2003 | 04:20 AM
nevin's Avatar
motor is a turbo 90-91 b18a.
Old Oct 29, 2003 | 04:45 AM
JimBlake's Avatar
Default Re: (nevin)
Another possibility - turbo bearings can leak oil, make a small puddle in the exhaust. That burns up when you start...
Old Oct 29, 2003 | 06:56 AM
nevin's Avatar
well its a new turbo actually and it did that when i was n/a too
Old Oct 29, 2003 | 09:35 AM
LoSt is BlaCk's Avatar
Default Re: (nevin)
you could have a kink in the return line or it could be too small of a return! i did see that you said it smoked before however you could take a look at the oil line also!
roll8221
Feb 5, 2015 05:30 AM
Hiboost 2.0
Aug 14, 2011 06:34 PM
superslow-oto
Jun 11, 2008 10:57 AM
playAho
Apr 16, 2004 04:57 PM
bQQsted hybrid
May 23, 2002 06:01 AM
