Need help car wont start
Old Oct 28, 2003 | 04:22 PM
WhiteWhiteTeg's Avatar
Default Need help car wont start
I need help, I was driving my brother 92 civic LX stoped at trafic light. When light turned green, once I step on accelerate the car stalled and won't start again. I checked there is no ground injector pulse signal from ECU, but do have power. I removed the inlet fuel pipe on fuel filter there is no fuel when ignition key on. Fuel pump seem like doesn't turn on when ignition key on. My guess is the Fuel pump relay gone, is it possible?
Anyone know where is the fuel pump relay locate? According from service manual it say on driver side fuse holder area. But I can't find it. Also anyone know the parts # of fuel pump relay?
HELP
Old Oct 28, 2003 | 10:26 PM
PHiZ's Avatar
Default Re: Need help car wont start (WhiteWhiteTeg)
The main relay (controls fuel pump) is notorious for overheating...
-PHiZ
Old Oct 29, 2003 | 01:32 AM
Default Re: Need help car wont start (PHiZ)
where is that locate?
Old Oct 29, 2003 | 07:15 AM
sleepyEK's Avatar
the main relay is located under the dash, you probably need a new one considering the multitude of them i have replaced on hondas and acuras.
Old Oct 29, 2003 | 10:20 AM
pro1342's Avatar
39400-S10-003....located above the under-dash fuse box.
Old Oct 29, 2003 | 02:10 PM
Default Re: (pro1342)
is the relay has 7 pins connector? I found one relay, but only has 4 pins connector.
Old Oct 30, 2003 | 04:39 PM
Default Re: (WhiteWhiteTeg)
I found the relay. I also found out the car has no spark. I m sure Distributor cap, rotor, coil and ignitor all good. cause I swaped it to another car to tested it.
what can make the car no spark , no fuel, injectors no signal from ECU, no power to fuel pump??
Help Help....
Old Oct 30, 2003 | 08:38 PM
vx_hatch's Avatar
your main relay.....need to get a new one
Old Oct 31, 2003 | 01:32 AM
Default Re: (vx_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vx_hatch &raquo;</TD></TR><TR><TD CLASS="quote">your main relay.....need to get a new one</TD></TR></TABLE>
main relay = fuel pump relay?
Old Oct 31, 2003 | 04:38 AM
JimBlake's Avatar
Honda puts the fuelpump relay together with relays that power the ECM & the distributor. All one unit, they call it a main relay.
Old Oct 31, 2003 | 04:24 PM
Default Re: (JimBlake)
I put in a new relay today, car still won't start
any one know where I can download a wiring diagram for 92 civic LX??? I need it.
Old Nov 9, 2003 | 06:22 AM
Fixed it guys. The ECU was fried. But I dun know what cause it.
Put in another ECU it runs.
Old Nov 9, 2003 | 08:29 AM
doublejz's Avatar
try putting your old 1 back in. It could have just needed reset
EJ8CIVIC
Jul 7, 2015 03:47 AM
dszer89
Jul 22, 2010 04:41 PM
blaze_125
Jun 16, 2008 08:15 AM
Lsweez
Jun 28, 2007 10:08 PM
