koni yellow users (brake lines)
Old Oct 28, 2003 | 07:16 AM
speedevo's Avatar
Default koni yellow users (brake lines)
did you guys just use zip-ties or how did you mount the brake lines afterwards to the shock?
Old Oct 28, 2003 | 07:18 AM
Dave-ROR's Avatar
Default Re: koni yellow users (speedevo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedevo &raquo;</TD></TR><TR><TD CLASS="quote">did you guys just use zip-ties or how did you mount the brake lines afterwards to the shock?</TD></TR></TABLE>
transfer the stock brake line holders from the OEM shocks to the Konis. I haven't used koni's myself but this works on most shocks.
Old Oct 28, 2003 | 07:23 AM
speedevo's Avatar
Default Re: koni yellow users (Dave-ROR)
do i just tap it out with a hammer? thanks
Old Oct 28, 2003 | 08:05 AM
uncleben's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedevo &raquo;</TD></TR><TR><TD CLASS="quote">do i just tap it out with a hammer? thanks </TD></TR></TABLE>
yes, that's what i did on my civic anyhow...
Old Oct 28, 2003 | 08:46 AM
92TypeR's Avatar
FSAE
Default Re: koni yellow users (uncleben)
^^ yup, transfer the holders onto the yellows and problem is solved.
I have both, and there is no clearance problems.
Old Oct 28, 2003 | 08:54 AM
Tweakmeister's Avatar
Default Re: koni yellow users (92TypeR)
I didn't do this - I used zip ties.
although, if the car needs to pass inspection, they require the lines to be bolted down.
Old Oct 28, 2003 | 09:23 AM
DutchITR1689's Avatar
Strange, my KONIs came with those holders. It's painted yellow too....
Old Oct 28, 2003 | 09:42 AM
Default Re: koni yellow users (DutchITR1689)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DutchITR1689 &raquo;</TD></TR><TR><TD CLASS="quote">Strange, my KONIs came with those holders. It's painted yellow too....</TD></TR></TABLE>
...must be a European thing?!?
Old Oct 28, 2003 | 09:47 AM
Chris93Si's Avatar
Default Re: koni yellow users (Tweakmeister)
Stupid holders won't fit over Zeals, zip ties for me. But if they'll fit definitely use them.
Old Oct 28, 2003 | 10:04 AM
Asahi's Avatar
Default Re: koni yellow users (Chris93Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris93Si &raquo;</TD></TR><TR><TD CLASS="quote">Stupid holders won't fit over Zeals, zip ties for me. But if they'll fit definitely use them.</TD></TR></TABLE>
They fit on my zeals. I have them bolted down as we speak (type)
Old Oct 28, 2003 | 10:35 AM
Chris93Si's Avatar
Default Re: koni yellow users (Asahi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Asahi &raquo;</TD></TR><TR><TD CLASS="quote">They fit on my zeals. I have them bolted down as we speak (type)</TD></TR></TABLE>
Hmmm I couldn't get them on mine, perhaps I didn't try hard enough
Old Oct 28, 2003 | 01:06 PM
mrlegoman's Avatar
The biggest problem with the zip ties is that if your using a steel braided brake line it will rub all the paint off the Koni's.
Old Oct 28, 2003 | 01:59 PM
Chris N's Avatar
not for long....
93CivicSI
Aug 14, 2009 07:22 PM
bopbop93030
Suspension & Brakes
Nov 10, 2008 01:07 AM
bopbop93030
Suspension & Brakes
Nov 4, 2008 11:48 AM
Chronicsinners
Aug 23, 2004 04:15 PM
TypeR 599
Feb 2, 2004 05:00 AM
