p72 hondata
Old Oct 28, 2003 | 12:07 AM
trusttuned's Avatar
Default p72 hondata
ok, maybe i'm missing something here...but a friend of mine is going w/ a hondata s200 system on his 98 type-r and as we all know(or most) you have to use a obd-1 ecu, he aquired a p72 from a friend, who was using it in his 98 gsr(straight up no hondata)... with no conv. harness, he said it was an obd-1, correct me if i'm wrong(which i hope i am) you have to use a conversion harness to run the ecu...both my friend and the guy w/ the gsr are just plugging it straight into the stock wiring harness ....what the hell is up w/ this?? it worked in the gsr...how can i tell if it is in fact an obd-1 ecu...2 sockets instead of 3?? serial numbers?...it says p72 in part of the label...
Old Oct 28, 2003 | 02:31 AM
rjardy's Avatar
Default Re: p72 hondata (trusttuned)
its an OBD2 ecu, their on crack.
Rob
Old Oct 28, 2003 | 06:46 AM
trusttuned's Avatar
Default Re: p72 hondata (rjardy)
how can I tell if it is an obd-2 or 1.....I would love to take your word for it, but need to know for sure(I am 90% sure as well thats it's an obd-2, but just need to confirm)
Old Oct 28, 2003 | 01:27 PM
Wes V's Avatar
The only OBD! P72 ECU should be marked as P72A1 and was used only on 94/95 GSR's. The ECU's for 96 and newer are OBD2. The OBD2 ECU's were also tagged as P72, but were not "A1" versions. Ask the dealer to confirm it.
The reason I know is that I'm putting together a 95 B18C (for a swap) and will have to go through the Referee.
Wes.
Old Oct 28, 2003 | 03:48 PM
baphomet's Avatar
Default Re: p72 hondata (Wes V)
hondata sells obd1 ecus with obd2 connectors but as far as I know they are only p28s.
Old Oct 28, 2003 | 10:34 PM
PHiZ's Avatar
Default Re: p72 hondata (slashDEVslashNULL)
Yeah, It could be internally converted, and if it is plugging into OBD2 cars, that is a telltale sign.
Just have to be careful between OBD1 and OBD2. But I think the plugs are keyed so you don't have to worry about mis-matching them.
-PHiZ
Old Oct 29, 2003 | 10:58 AM
rjardy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trusttuned &raquo;</TD></TR><TR><TD CLASS="quote">how can I tell if it is an obd-2 or 1.....I would love to take your word for it, but need to know for sure(I am 90% sure as well thats it's an obd-2, but just need to confirm)</TD></TR></TABLE>
Just based on the fact that they are bothing using OBD2 cars....
Rob
Old Oct 29, 2003 | 08:16 PM
PHiZ's Avatar
DOH! I meant to say OBD2A and OBD2B, not OBD1 and OBD2!
-PHiZ
connor53
Engine Management and Tuning
Oct 5, 2008 02:15 PM
eggie75
Aug 8, 2008 11:28 AM
mitchell_2kSiR
Dec 30, 2007 09:32 AM
trusttuned
Feb 21, 2004 11:58 AM
DC2 B18C TSL
Nov 11, 2003 11:33 PM
