MIL Trouble.....HELP
Old Oct 27, 2003 | 11:30 AM
kingmonkey's Avatar
Default MIL Trouble.....HELP
Alright. I just put a 4-1 header on my 00 sohc 1.6L. I hooked up both o2 sensors. And now my check engine light is on. Since I am not using a cat. Should I remove the 2nd o2 sensor? The car still runs, but now has a slight miss due to running rich. Any ideas of how to fix this problem?
Old Oct 27, 2003 | 12:15 PM
poison's Avatar
Default Re: MIL Trouble.....HELP (kingmonkey)
The secondary O2 sensor will not cause your motor to run rich. If you have the primary O2 sensor not hooked up right, then it will cause you to run rich if throwing the code.
Check the codes...
Old Oct 27, 2003 | 02:05 PM
kingmonkey's Avatar
Default Re: MIL Trouble.....HELP (poison)
both are hooked up correct. I was told I might not be able to use both O2 sensors. Is the a way to eliminate the sencondary sensor?
young geezer
May 25, 2010 07:02 PM
odishaw
Feb 16, 2008 08:34 AM
wootcivic
Nov 29, 2004 10:01 AM
boost fed ls
Aug 31, 2004 07:45 PM
ATS*Mark
Apr 7, 2004 07:06 AM
