Settle a Dispute...LS VTEC vs Type R
Old Oct 26, 2003 | 09:57 PM
BrokenLimits's Avatar
Default Settle a Dispute...LS VTEC vs Type R
So I am building an LS VTEC:
B16 Head
AEBS IM
Je 12.2 Pistons
Eagle Rods
LS Crank
Type R Cams and Valve Springs
Skunk 2 Cam Gears
Hondata S200
Type R Oil Pump
Balanced and Blue Printed Block
Knife Edged Crank
ACL Bearings
(Probably leaving out a few things)
His Type R:
CTR Pistons
Skunk2 Stage 2 Cams (valve Springs and Retainers)
Sunk 2 Cam Gears
Hondata
So....who will make more HP and Torque?
Old Oct 26, 2003 | 10:45 PM
LudeyKrus's Avatar
I'd put my money on the R.....
hybrid motors make good torquey motors, but for a straight up power motor, the high-revving, well-designed R's will rip it up.
Old Oct 26, 2003 | 11:13 PM
Formula 1's Avatar
Default Re: (LudeyKrus)
the R should only lay down 175WHP give or take 5WHP... i think you got him beat
Modified by SikCivic at 12:56 AM 10/27/2003
Old Oct 26, 2003 | 11:27 PM
leadfoot78's Avatar
Default Re: Settle a Dispute...LS VTEC vs Type R (BrokenLimits)
If you are both tunned propertly it will be close on the power, u will have better torque through the whole power band, thats assuming everything is running right. My 2.0 ls has u both though.
Old Oct 26, 2003 | 11:57 PM
gsrvx's Avatar
New User
I think he'll edge u out on the HP...but you'll have the torque on him.
Old Oct 26, 2003 | 11:58 PM
Formula 1's Avatar
Default Re: Settle a Dispute...LS VTEC vs Type R (ibspecHATCH)
i don't think its a contest
Old Oct 27, 2003 | 06:48 AM
Anyotherone's Avatar
I think that both setups should be good for 200whp. I would say that properly tuned, the ITR will make more peak torque, with torque coming on sooner for the LSVTEC.
Old Oct 27, 2003 | 07:28 AM
Formula 1's Avatar
Default Re: Settle a Dispute...LS VTEC vs Type R (C_tech97GSR)
you are lookin at about the same compression ratio...but u should rev farther and your bottom end beats his
Old Oct 27, 2003 | 08:43 AM
Default Re: Settle a Dispute...LS VTEC vs Type R (SikCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SikCivic &raquo;</TD></TR><TR><TD CLASS="quote">..but u should rev farther and your bottom end beats his</TD></TR></TABLE>
Umm... how do you figure that? He has a stock ITR valvetrain and cams, so he's not going to rev higher than The ITR. With a full skunk2 valvetrain and stage 2 cams the ITR can make power to 9K RPMS or maybe more.
Old Oct 27, 2003 | 08:44 AM
StyleTEG's Avatar
Can I vote for "it doesn't matter?"
Peak HP/TQ figures mean next to nothing
Old Oct 27, 2003 | 08:54 AM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
i would leave the crank instead of knife edging if u want even more torque...(depending how much the crank is knifed/lightend)..with the compression and cams that the itr is using i think the itr will make more hp...torque not to sure...just MY OPINION.
Old Oct 27, 2003 | 10:34 AM
Default Re: Settle a Dispute...LS VTEC vs Type R (bruceleeroy)
yeah I have actually thought about that...
Good answers...so I guess its going to be close...but I dont like that so I might order some cams LoL...
Old Oct 27, 2003 | 10:41 AM
SYD's Avatar
SYD
now your talkin!
Old Oct 27, 2003 | 05:15 PM
Alrght so the new question...
Slight weight reduction on the Si vs the Type R....1/4 mile estimates with good drivers and who would win...
Old Oct 27, 2003 | 05:35 PM
gsrvx's Avatar
New User
how about **** the estimates, go race and find out
Old Oct 27, 2003 | 06:41 PM
oh we will...
Old Oct 27, 2003 | 06:46 PM
(__________)'s Avatar
I think the ITR will win if you 2 run cause traction will be a slight problem for the SI
Old Oct 27, 2003 | 08:12 PM
LudeyKrus's Avatar
Default Re: Settle a Dispute...LS VTEC vs Type R (steves98itr247)
I think the R will win b/c of the better gearing.
Old Oct 27, 2003 | 09:58 PM
trusttuned's Avatar
Default Re: Settle a Dispute...LS VTEC vs Type R (LudeyKrus)
your missing a few things from his list brandon...i thought you were going to change that...here is the type-r's list....complete top to bottom
p&p'd head, reworked combustion chbr
skunk2 swirl polished valve set- stock size, stdrd comp.
skunk2 valve train- springs, ret. etc.
skunk2 stage 2 cams
skunk2 cam gears
CTR pistons
stock rods
micropolished crank
balanced rotating assmbly
hondata s200
bolt ons:
powercore 4-1 header 2.5" collector
aem cold-air
powercore high flow cat
powercore 2.5" exhaust
Old Oct 27, 2003 | 10:31 PM
Formula 1's Avatar
Default Re: Settle a Dispute...LS VTEC vs Type R (trusttuned)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trusttuned &raquo;</TD></TR><TR><TD CLASS="quote">your missing a few things from his list brandon...i thought you were going to change that...here is the type-r's list....complete top to bottom
skunk2 stage 2 cams
skunk2 cam gears
CTR pistons
stock rods
micropolished crank
hondata s200
bolt ons:
aem cold-air
looking at that...give up now
Old Oct 27, 2003 | 11:41 PM
trusttuned's Avatar
who?..the lsvtec or the type-r?...and if it's the ls vtec.....lol!!!!!!!!!!!!! ....give up? i say it will be a close hp race, more high end hp and peaky tq curve for the r, lsvtec.. less hp, flatter tq curve....but give up?? no way dood and
"the R should only lay down 175WHP give or take 5WHP..." -sikcivic
he lays close to that stock...check your info dude..that setup is good for over 200whp
Old Oct 28, 2003 | 02:57 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus &raquo;</TD></TR><TR><TD CLASS="quote">I think the R will win b/c of the better gearing.</TD></TR></TABLE>
They have the same gearing
Old Oct 28, 2003 | 07:20 AM
igotyofire's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steves98itr247 &raquo;</TD></TR><TR><TD CLASS="quote">
They have the same gearing </TD></TR></TABLE>
similiar gearing , but lets not forget the LSD and the fact that the ITR weighs less then the Si , u said a lil weight reduction so who knows how much your talking about, its close but i wouldn't be to cocky anything can happen, skunk2 stage2 pulls hard up top!
Old Oct 29, 2003 | 05:24 PM
1fast4's Avatar
Default ITR Finished
Lets stop the bullshit when I get my ITR built and finish, its on. O buy the way have fun looking at my tail lights if you can see them LOL
Old Oct 29, 2003 | 05:37 PM
Formula 1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trusttuned &raquo;</TD></TR><TR><TD CLASS="quote">who?..the lsvtec or the type-r?...and if it's the ls vtec.....lol!!!!!!!!!!!!! ....give up? i say it will be a close hp race, more high end hp and peaky tq curve for the r, lsvtec.. less hp, flatter tq curve....but give up?? no way dood and
he lays close to that stock...check your info dude..that setup is good for over 200whp</TD></TR></TABLE>
sry when i made that statement i was thinking the r was close to stock....sry
