milling question......tunners
Old Oct 26, 2003 | 11:30 AM
AMZ GS-R's Avatar
Default milling question......tunners
my tunner say that my head and block are too much milled like 20 the head (gsr) and 20-25 the block due to over heating and usdm t.r. piston and my cam gears are not line up like stock and the car feels like crap , how can i fix my timing thanx in advance......
Old Oct 26, 2003 | 01:04 PM
DVS_EF's Avatar
Default Re: milling question......tunners (AMZ GS-R)
make sure that both your adj. cam gears are set at zero, then double check if it's on TDC, if not, line it up.. hope this helps...
Old Oct 26, 2003 | 07:20 PM
AMZ GS-R's Avatar
thanx man but they just move when i adjust the timing belt.......
Old Oct 27, 2003 | 07:23 AM
AMZ GS-R's Avatar
Default Re: (AMZ GS-R)
Old Oct 27, 2003 | 08:18 PM
AMZ GS-R's Avatar
dam nobody seem to know this type of problem...........
Old Oct 27, 2003 | 08:51 PM
MAX_CFM's Avatar
CAm gears will fix it
93solsi's Avatar
when you mill a head and block you must account for the loss in material in order to get correct timing of the motor. I'm not sure but I think its 012" = 1 degree. so for every 12 thou your cams are retarded 1 degree. so it sounds like you need to advance your gears about 3-4 degrees each to get everything back in line. you can check everything with a timing gun to make sure.. HTH
Old Oct 28, 2003 | 08:29 AM
AMZ GS-R's Avatar
thanx, very helpful
neofreak
25
Jan 1, 2007 12:33 PM
Nsane1
17
Jul 2, 2005 08:47 AM
kartracer4
Jun 27, 2005 05:36 PM
mtber
Feb 28, 2004 12:11 AM
sporkcrx
Sep 24, 2002 07:51 PM
