automatic to 5 speed conversion
has any one in here turned there automatic into a 5 speed? im gettin ready to do this conversion in a few weeks and im not sure if im getting in over my head or notand what all does it take to do this conversion?
ok, before you hear it... do a search. its covered many times....
THERE. i have already stated it politely so everybody...no need for the flaming and "do a SEARCH n00b" posts...
to be helpful....what car are you doing the conversion in? and if you dont know what your doing very well. it is a very big project. if it is a cable tranny (88-91 cars) then it will be a little easier, but then again, you wouldnt be posting in this forum.
you'll need to change the tranny, ecu, pedal cluster, get a clutch, get a flywheel, get manual transmission flywheel bolts(longer threads), get shift linkage, shifter stablizer bar, shifter, shift boot, shift ****, manual tranny cluster(not needed, but that way you dont have the auto line in the cluster), instal a master cylinder for the clutch with a resevoir(if hydro tranny), run hydrolic line for the tranny. get a slave cylinder for the tranny, i think the engine harness should work? axels and engine mounts.. i think the manual and auto are the same? maybe not? i might be forgetting something? but yes, very big job.
so are you doing a b-series swap or you just changing out the auto tranny for a manual tranny on you sohc.....??
i've done the conversion on my car and if you have any questions let me know
i have done this a couple of times. whatever you need hit me up i can get you all you need and can help answer some questions you might have
howmuch money does it usually cost to change the transmission from auto to manual in (canadian dollers). i wanna do it for my 97 civic ex....... either by my self or at a store
