best way to know if head gasket is blown ?
Old Oct 26, 2003 | 09:15 AM
thompson324's Avatar
Default best way to know if head gasket is blown ?
Hello, i am wondering how will i know if my head gasket is blown ? i dont see any smoke from the engine head, i do have alittle white smoke from the exhaust tip. and i did a compression test and all cylinders were well below the spec ? any other way to tell so i can make it a more defenite ? thanks in advance !!
Old Oct 26, 2003 | 09:21 AM
80884's Avatar
Default Re: best way to know if head gasket is blown ? (thompson324)
Leak down test, that will tell you if it's leaking, where your losing compression and 99.9% of the time will point out the problem
white = coolant or water
Old Oct 26, 2003 | 09:38 AM
Gunns's Avatar
Leak down test
Its your best bet.
Old Oct 26, 2003 | 10:29 AM
Default Re: best way to know if head gasket is blown ? (Gunns)
is there something i can buy to do a leak down test? if so whats the name ? and doesnt that have to be done with a air compressor ? cause i dont have one
Old Oct 26, 2003 | 12:02 PM
80884's Avatar
Leak down tester - thats pretty much what it's called, and yes you need a way to pressurize the cylinders, air compressor, or maybe and air tank? like the ones used to fill tires up, but you will still need a compressor to fill that up so idk what you will have to do as these are the ony 2 ways i have ever done it.
Old Oct 26, 2003 | 01:37 PM
91integraLSVTEC's Avatar
Default Re: best way to know if head gasket is blown ? (80884)
open your radiator cap, and start your engine.. if water/coolant jumps out, your headgasket is blown..
Old Oct 26, 2003 | 01:43 PM
80884's Avatar
Default Re: best way to know if head gasket is blown ? (91integraLSVTEC)
thats one easy way to tell but it won't necessarly do that if the headgasket is bad....i've seen bad headgaskets leak just oil, just water, or leak oil, or water but not into the engine, but in his case yes, since he has white smoke.
what were the comp test #'s? were they all about the same?
Old Oct 26, 2003 | 02:39 PM
yes all the compression tests were about the same, ummm i think they were like 120 or so, does that mean anything ? i know it should be like 180 or so, so your saying that the air tanks to fill tires like at a gas station are good to use for it ? cause i have a gas station right across the street i can get the car too ? and how to i do a leak down test ? same as the compression test? and what numbers am i looking for ? thanks again!
Old Oct 26, 2003 | 02:51 PM
80884's Avatar
https://honda-tech.com/zerothread?id=399709
https://honda-tech.com/zerothread?id=386663
https://honda-tech.com/zerothread?id=438893
Good info in those links......... basicly, with all valves closed in the cylinder you are testing, you pressurize it with air and see how much air it leaks, and where it is going. then you will know what is up.......read the links and if you need more help let us know.
moonleyet
Dec 17, 2009 02:07 PM
88 EF Hatch
Jul 11, 2009 09:50 PM
GSR936
Apr 28, 2009 06:10 PM
TegraD
Nov 9, 2008 01:49 PM
FLIPboi
Dec 4, 2002 03:25 PM
