whacked alignment after swaybar install?
Old Oct 26, 2003 | 06:29 AM
an2ny888's Avatar
Default whacked alignment after swaybar install?
Just installed an itr front swaybar and lower control arms on my EG, problem is my steering wheel isnt centered anymore after the install. Logic says my alignment shouldnt have changed because i didnt touch the tie rods. Can anyone offer some insight on this?
Old Oct 26, 2003 | 06:57 AM
WangChung's Avatar
Default Re: whacked alignment after swaybar install? (an2ny888)
i have noticed that my wheel isnt centered either, is it a bad thing? cant u just take it off and rotate it on the splines till its aligned?
Old Oct 26, 2003 | 08:10 AM
D50boy's Avatar
You should have an alignment done after doing anything to your suspension
Old Oct 26, 2003 | 08:16 AM
deepnite's Avatar
Default Re: whacked alignment after swaybar install? (D50boy)
ur alignment is more prone to change whenever u touch any of ur suspension parts..playing with ur tie rods is equivalent to hitting a pot hole without the permanent damage to parts..ur misalign d steering wheel would suggest that the inner tie rod needs adjustment
Old Oct 26, 2003 | 09:19 AM
HulkSmash's Avatar
did you tighten the endlinks down with the suspension loaded?
Old Oct 26, 2003 | 10:47 AM
EG8R's Avatar
Default Re: whacked alignment after swaybar install? (97civhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97civhatch &raquo;</TD></TR><TR><TD CLASS="quote">i have noticed that my wheel isnt centered either, is it a bad thing? cant u just take it off and rotate it on the splines till its aligned?</TD></TR></TABLE>
lmao Are you serious?
Old Oct 26, 2003 | 04:06 PM
WangChung's Avatar
Default Re: whacked alignment after swaybar install? (skelly ed6)
yeah, i was. do i need an alignment just because my wheel is crooked? i just recently got an alignment, so i thought maybve they left the wheel a little crooked by accident. kinda a noob at this alignment biz.
Old Oct 26, 2003 | 04:55 PM
an2ny888's Avatar
I tightened the endlinks with the car on jackstands and the wheels off. would this throw the alignment off?
Old Oct 27, 2003 | 03:43 PM
WangChung's Avatar
so, if my steering wheel is crooked, is my alignment off? i know ur all thinking, "what a douchebag", but what if the guy i got my car aligned at left the wheel a little cocked? when i am going straight, the wheel doesnt shudder/shake, and it doesnt pull to one side, unless my azenis get a hold of a groove or dip in the road.
Old Oct 27, 2003 | 04:20 PM
screech's Avatar
if your wheel isnt straight you need to take it back to the place you got it aligned, they are supposed to fix that when they align it. and always get your car aligned after any suspension modifactions.
4doorteggy
11
Dec 16, 2009 01:00 PM
Corksil
Oct 14, 2009 05:37 PM
kaluwa3
Jun 6, 2008 08:31 PM
Shingo
17
Jun 27, 2007 02:58 PM
jdmeg9
Jan 8, 2005 03:38 PM
