removed power steering belt (will loop set up hep)?
today i took off my ps belt and i like the feel of the car without the ps but it is way to hard to turn. i was thinking of doing the loop set up with res as a breather. will that help make the wheel easer to turn? or should i just put the belt back on and deal with a floaty car?
i cant stand driving on the highway with the teg ps
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oMekoneDC2 »</TD></TR><TR><TD CLASS="quote">today i took off my ps belt and i like the feel of the car without the ps but it is way to hard to turn. i was thinking of doing the loop set up with res as a breather. will that help make the wheel easer to turn? or should i just put the belt back on and deal with a floaty car?
i cant stand driving on the highway with the teg ps</TD></TR></TABLE>
Removing/bypassing the pump and running your own lines and breather will definitely result in less steering effort, as well as weight-savings.
What exactly is the right way to do this mod? Do you just pull the hoses off of the PS pump, connect them together with a T, and put a filter on that T? I've never heard the actual details for this...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Weston »</TD></TR><TR><TD CLASS="quote">What exactly is the right way to do this mod? Do you just pull the hoses off of the PS pump, connect them together with a T, and put a filter on that T? I've never heard the actual details for this...</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=538087
https://honda-tech.com/zerothread?id=184202
https://honda-tech.com/zerothread?id=563724
https://honda-tech.com/zerothread?id=462824 <-- cleanest 1 ive seen so far
i really think im gona try this. padawan sells a kit for like 70$ shipped he posted right above you check the link in his sig
turbotime
May 27, 2006 04:54 PM
