E Brake Light stays on while driving....
Old Oct 25, 2003 | 07:49 PM
redacura's Avatar
Default E Brake Light stays on while driving....
My e-brake is not activated, my guess is low brake fluid? I was told i have dirty brake fluid several times by the acura dealer.
Old Oct 25, 2003 | 08:24 PM
TEXN3's Avatar
Default Re: E Brake Light stays on while driving.... (redacura)
the brake light is not only for the e-brake. it is for the brake system. most likely a fluid problem.
Old Oct 25, 2003 | 11:41 PM
SMZ GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redacura &raquo;</TD></TR><TR><TD CLASS="quote"> my guess is low brake fluid? I was told i have dirty brake fluid several times by the acura dealer. </TD></TR></TABLE>
Could be both. Take a look at your fluid level.
Old Oct 26, 2003 | 01:26 AM
B16OnTop's Avatar
if i had a dime for every time this topic came up, then id have a turbo by now
Old Oct 26, 2003 | 07:18 AM
GSR44's Avatar
i have this same problem on cold mornings...i've checked the fluid level and it's fine. is there anything else i should do? i'm pretty much due for a fluid flush right now, but i dont know if that would be the cause of this...any other thoughts?
Old Oct 26, 2003 | 07:49 AM
Passaudi1.8t's Avatar
New User
Default Re: (GSR44)
It's possible you have air in your brake lines. For the longest time, my light would come on from time to time, and somedays the fluid would be up to the Max, other days it would be near the Min level. I checked the m/c, and all lines, no leaks... so I summed it up to an air bubble in the system, also because my brakes felt mushy somedays and really stiff others. I still have yet to have the system bled completely, I did a crappy job when replacing my rear brakes last spring. Doh
Old Oct 26, 2003 | 03:46 PM
redacura's Avatar
Default Re: (B16OnTop)
&lt;&lt;
umm i tried a search..nothing came up.. i tried- ebrake light - e brake etc.. several ways... and nothing buddy.
Old Oct 26, 2003 | 03:53 PM
LSTEG96's Avatar
Default Re: (redacura)
sometimes i have this problem, but it happens when the e brake goes to the point where the light shuts off, and its not activated, then past that point and the light comes on again... i cant figure this out!
Old Oct 26, 2003 | 03:59 PM
B16OnTop's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redacura &raquo;</TD></TR><TR><TD CLASS="quote">umm i tried a search..nothing came up.. i tried- ebrake light - e brake etc.. several ways... and nothing buddy.</TD></TR></TABLE>
really?
https://honda-tech.com/zerothread?id=57157
https://honda-tech.com/zerothread?id=637558
https://honda-tech.com/zerothread?id=635309
https://honda-tech.com/zerothread?id=605881
and there was 244 other threads just like yours
Old Oct 26, 2003 | 06:30 PM
integraL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16OnTop &raquo;</TD></TR><TR><TD CLASS="quote">if i had a dime for every time this topic came up, then id have a turbo by now</TD></TR></TABLE>
so you're saying you saw 50,000 topics on the brake light?
Old Oct 26, 2003 | 06:34 PM
JadeDM's Avatar
GUYS... no need to fight...... help this guy with the problem
Old Oct 26, 2003 | 06:41 PM
B16OnTop's Avatar
Default Re: (integraL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraL &raquo;</TD></TR><TR><TD CLASS="quote">
so you're saying you saw 50,000 topics on the brake light?</TD></TR></TABLE>
figure of speech my friend, and a turbo doesn't cost 5k, maybe a kit but not a turbo
Old Oct 26, 2003 | 06:43 PM
Komsomol's Avatar
I have this problem too in my talon.
Hrm.
Old Oct 26, 2003 | 07:23 PM
integraL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16OnTop &raquo;</TD></TR><TR><TD CLASS="quote">figure of speech my friend, and a turbo doesn't cost 5k, maybe a kit but not a turbo</TD></TR></TABLE>
i can understand sarcasm man. and i was joking
Old Oct 26, 2003 | 07:47 PM
tqhill3's Avatar
had the same problem for a while. Found out my caliper was leaking in the front and causing low amount of brake fluid. Got it replaced and solved the problem.
Old Oct 26, 2003 | 08:49 PM
babes 99 GSR's Avatar
Default Re: (tqhill3)
Sensor? My sensor is screwed up cuz there are no other problems and mine is always on if it is like less than 45 degrees when i start the car...
And yes, this topic has been discussed a lot...hell, i think i even brought it up a few months ago.
-Staci
Old Oct 26, 2003 | 09:15 PM
GirlyGS-R's Avatar
Default Re: (99GSR1980)
this happened to mine a few months ago, check the fluid level and check to see if the floater(sensor) is working properly. it should be covered under the warranty.
Old Oct 26, 2003 | 09:25 PM
silvernick711's Avatar
Default Re: (GirlyGS-R)
check the fluid level on the abs.
Old Oct 26, 2003 | 11:51 PM
94civicEX's Avatar
Mine does that too. It only started when it began to get colder than 40°.
As the exhaust heats up underneath the e-brake it goes off...kind of weird.
Old Oct 27, 2003 | 01:01 AM
slomob18b's Avatar
By any chance did you add the type r rear swaybar? I noticed my ebrake light coming on sometimes and it goes away later. The fluid is always full too. I am guessing if might have something to do with the ABS lines just hanging there after doing the type r rear swaybar install.
type-GGSR
Jan 28, 2008 11:22 PM
Z7
10
Aug 6, 2006 01:17 PM
Ha7chB4cK
May 3, 2005 06:06 PM
aeongap
Dec 5, 2004 02:40 PM
Sam268
Jul 30, 2003 11:01 AM
