Fuel Grade: Does it matter?
Old Oct 25, 2003 | 11:33 AM
FifthGen's Avatar
Default Fuel Grade: Does it matter?
1996 Honda Accord LX (2.2L non-vtec) Automatic.
I have been using 87 octane forever.
I have been told that if I use 91 octane (the highest available pump where i live) it will not make a difference and I will be wasting money, if not getting poorer fuel economy.
Is this true?
with mods-cai, cat-back exhaust, is this still true?
kk
Old Oct 25, 2003 | 11:50 AM
sauceman's Avatar
Default Re: Fuel Grade: Does it matter? (FifthGen)
Absolutely true.
Your engine is made for 87, and since higher octane gas resists more to explosion, it might lower your performance.
I have found my times at the track to be slightly better with 87 than with 91 octane on my 95 EX.
Same should go for you. High octane is for high compression.
Old Oct 25, 2003 | 11:55 AM
FifthGen's Avatar
Default Re: Fuel Grade: Does it matter? (sauceman)
thanks for info
Old Oct 25, 2003 | 03:42 PM
fluxion's Avatar
amin n'rangwa edanea
i run 93 simply cuz it burns cleaner, peformance increases are non-existant, but it hasnt hurt any from what i can tell.
Old Oct 26, 2003 | 06:01 AM
AccVic's Avatar
Default Re: Fuel Grade: Does it matter? (fluxion)
I get better gas mileage running 87 octane over running 93 octane in both my cars
Old Oct 26, 2003 | 06:21 AM
LsVtec805's Avatar
Default Re: Fuel Grade: Does it matter? (accordrider)
i dunt knoe why but sum people still think that higher octane gives power. all it does is burns better and helps prevent ur motor from dentonating.
Old Oct 26, 2003 | 07:41 AM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fluxion &raquo;</TD></TR><TR><TD CLASS="quote">i run 93 simply cuz it burns cleaner, peformance increases are non-existant, but it hasnt hurt any from what i can tell. </TD></TR></TABLE>
no, it does hurt, first of all, there's a "quich" area, 93 is harder to burn completely and it burn slow, the leftover of the unburn gasoline over a long period of time will become carbon deposit, the black tar like sh-t on the piston surface, which in some case, it will overheat and start a flame front and cause denoation.
i dont know how much you guy paying for gas but I am broke and i want the 87
Old Oct 26, 2003 | 07:46 AM
iam7head's Avatar
Default Re: Fuel Grade: Does it matter? (LsVtec805)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsVtec805 &raquo;</TD></TR><TR><TD CLASS="quote">i dunt knoe why but sum people still think that higher octane gives power. all it does is burns better and helps prevent ur motor from dentonating. </TD></TR></TABLE>
the higher the rating the more resistance to start burning, the other word you need hotter spark to start the fire, it will resist to pre. ignition which happen alot with cheap gas from mexico or some place(those gas place with no rating, just plain GAS )
there's people been using 91(equal to 93 for non-cali residents) from day one and the car is addict/adjuste to the higher rating of fuel, over a long period of time and mileage, the car cannot run smoothly or as good without the higher octane fuel.
it just not nessccary, unless you using nitrous, turbo, sc or high compression NA built motor
and about the myth of power, high octane race gas like 105 will give you some noticeable horsepower, but emission will suffer so it's not idel for everyday pump gas operation, unless you live in middle of no where.
Old Oct 26, 2003 | 07:52 AM
iam7head's Avatar
Default Re: Fuel Grade: Does it matter? (iam7head)
here another concept, with the overheac cam engine design, the spark plug are sitting in the middle(not exactly right 100% in the middle but it's dame close), in the power stoke the sparkplug will give a spark, and the flame will start from the center of the chamber and spread out to the cylinder wall, here the problem, the temperture of the whole combustion chamber is not all equal, the temp. near the cylinderwall is cooler(metal take away heat and waterjacket,etc) which take away the heat nessarsy to make a complete/clean/all combustion of all the gasoline, some might say, who cares i got moola, but the problem is the unburn gasoline will leave deposit over time.
Old Oct 26, 2003 | 01:32 PM
DLB1994's Avatar
i run 110octane $4.30gal
Old Oct 26, 2003 | 02:15 PM
Razor's Avatar
Default Re: Fuel Grade: Does it matter? (DLB1994)
87 octane for any f-series motor found in the accord, unless you got major engine work done. anything with higher octane is just a waste of money, and as someone has already mentioned, will lower performance and gas mileage.
Old Oct 26, 2003 | 03:21 PM
accordfreak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DLB1994 &raquo;</TD></TR><TR><TD CLASS="quote">i run 110octane $4.30gal</TD></TR></TABLE>
haha dang cheap!! i run 100 octane for $4.60!
Old Oct 26, 2003 | 05:13 PM
NyTrYdEr AcCoRd's Avatar
damn this is good to know
Old Oct 27, 2003 | 11:14 AM
Drag-On23's Avatar
The only time you upgrade on fuel is when you are experiencing pinging with the curent fuel grade or if you are running forced induction, nitrous or some serious motor work (like high compression pistons).
Old Oct 27, 2003 | 12:18 PM
NathanMorris's Avatar
Default Re: Fuel Grade: Does it matter? (Drag-On23)
only in high compression or forced induced motors (or highly advanced timing wise) will you ever need to run 92. It ahs nothing to do with performance, it just has to do with how hard it is to combust.
- Nathan
Old Oct 27, 2003 | 03:08 PM
Razor's Avatar
Default Re: Fuel Grade: Does it matter? (92Lx)
don't know if this is true, but the new 03+ v6's can make more hp with higher octane. the engine is designed to make 240 hp with 87 octane, but if you put in higher octane, the timing is advanced and you get more hp. anyone here about this?
Old Oct 28, 2003 | 09:53 AM
Beach Accord's Avatar
Default Re: Fuel Grade: Does it matter? (Razor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Razor &raquo;</TD></TR><TR><TD CLASS="quote">don't know if this is true, but the new 03+ v6's can make more hp with higher octane. the engine is designed to make 240 hp with 87 octane, but if you put in higher octane, the timing is advanced and you get more hp. anyone here about this?</TD></TR></TABLE>
i have heard the same
-chris B
Old Oct 28, 2003 | 05:20 PM
LCDeuce's Avatar
Default Re: Fuel Grade: Does it matter? (Beach Accord)
i run 93 in my H22. when i first had the swap done i tried sticking with 87 but it ran like ****.
2k.civic.si
Sep 30, 2010 01:30 AM
SlowEJ8
48
May 2, 2009 06:44 AM
otacon122
Jul 13, 2007 05:15 PM
Motorgroove
Jun 14, 2004 08:14 AM
CrOmEdOmEcHaMbEr
10
May 9, 2002 11:41 AM
