Throttle Position ???
Old Oct 25, 2003 | 06:03 AM
90crxb16a's Avatar
Default Throttle Position ???
Gettting throttle position code. how do i fix. Car starts fine, but will not stay started. Thanks
Old Oct 25, 2003 | 06:23 AM
spaceman's Avatar
Default Re: Throttle Position ??? (90crxb16a)
check your TPS sensor on your throtle body,maybe you need to adjust it..i didnt know that the tps would cause your car not to run..i put my stock crx tps onto my b16 and i havnt even adjusted it yet and the motor runs fine..anyways good luck
Old Oct 25, 2003 | 06:38 AM
PhatOptimo's Avatar
You need a Volt-ohm meter Better known as a mulit-meter. Use a digital one. Find the TPs sensor and probe the middle wire (red). Ground the other lead. Turn the key to the on postition. Do not start the engine. Loosen the TPS mounting hardware and when you turn the sensor the voltage on the meter will change. With the throttle fully closed you should read as close to .5v as possible. Wide open throttle should read 4.5v Tighten the mounting hardware and recheck voltage. Reset ECU. HTH
Old Oct 25, 2003 | 07:35 AM
Grease Monkey's Avatar
Default Re: Throttle Position ??? (PhatOptimo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhatOptimo &raquo;</TD></TR><TR><TD CLASS="quote">You need a Volt-ohm meter Better known as a mulit-meter. Use a digital one. Find the TPs sensor and probe the middle wire (red). Ground the other lead. Turn the key to the on postition. Do not start the engine. Loosen the TPS mounting hardware and when you turn the sensor the voltage on the meter will change. With the throttle fully closed you should read as close to .5v as possible. Wide open throttle should read 4.5v Tighten the mounting hardware and recheck voltage. Reset ECU. HTH</TD></TR></TABLE>
What he says about adjusting your tps but I find it a bit odd that your car wouldnt stay on. I recently did a mpfi swap and my tps broke on the inside so I'm waiting for another one. Its not even connected and the car drives fine. I would click on the link before for troubleshooting codes. Let us know how it turns out.
dhdave2509
Engine Management and Tuning
Feb 20, 2010 08:59 PM
92prelude23
Jan 26, 2009 05:43 PM
137
Apr 1, 2005 12:23 AM
GSRcivicGSR
Dec 20, 2004 04:29 AM
gamakichi77
Feb 24, 2004 05:17 PM
