ItR LsD into a 94-01 LS tranny
Old Oct 24, 2003 | 08:07 PM
precord96's Avatar
Default ItR LsD into a 94-01 LS tranny
My friend needs some help. He had a gsR tranny, but decided to get an LS tranny for a turbo setup. He has an ItR lsd, and wants to put it in the LS tranny, what needs to be done to make it work?
So far we know the FD from the gsR has to go with the lsd. any help would help out lots, thanks.
Old Oct 25, 2003 | 12:40 AM
Downey's Avatar
Default Re: ItR LsD into a 94-01 LS tranny (precord96)
the GSR tranny will work better with his turbo. alot of people say the longer gears keep you in boost longer.. blah blah, but a friend of mine has a gsr turbo and he has done he research. but since you have the ls tranny already, take the 4.266 fd from the LS diff (bolts are reverse thread) and swap it onto the ITR lsd. next put the LSD inplace of the stock diff and button it all back up. pretty simple.
Old Oct 25, 2003 | 04:05 PM
precord96's Avatar
Default Re: ItR LsD into a 94-01 LS tranny (Downey)
He's telling me that the Fd from the LS wont bolt up. So having to bolt up the gsR fd.
Old Oct 26, 2003 | 01:36 AM
Downey's Avatar
if u use the GSR 4.400 final drive ur goign to have to use a main shaft with a 4.400 gear on it. the ls 4.266 will not work.
why wont the LS fd bolt to the itr lsd? differnt size? bolts a differnt offset?
Old Oct 26, 2003 | 08:13 AM
t72's Avatar
t72
pretty sure you can put lsd into a b18b tranny as long as you take the 5th gear from gsr or itr.
Old Oct 26, 2003 | 09:44 AM
Ls-Rturbo's Avatar
Default Re: (t72)
u got to get the final drive from a type r because the Ls or Gsr one dont fit the typeR Lsd is a little bigger. trust me i already went through this the hard way and payed some one to takes apart my tranny only to find out it dident fit. oh whell at least i got a clutch and fly wheel in.
Old Oct 26, 2003 | 12:09 PM
spoonek4's Avatar
Default Re: (bl18t)
From what I know is yes the DC2R/EK9's LSD are big size LSD. Both DC2 SiR/EK,EG SiR's LSD that comes in options are all small size LSD.
Old Oct 27, 2003 | 03:08 PM
Weston's Avatar
Default Re: (spoonek4)
Here's how a guy installed the Type-R LSD into a 3rd gen Prelude Si (B21 engine): http://ucsu.colorado.edu/~swinbank/lsd.htm
I don't know how similar the B21 tranny is to the LS tranny, but that info is still the best I've seen. From looking at that, it seems like you just need to swap the bearings, machine down the top, and then modify the final drive holes or something to get it to bolt up.
Old Oct 27, 2003 | 04:25 PM
shamoo's Avatar
Will you make something up for me please?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Downey &raquo;</TD></TR><TR><TD CLASS="quote">if u use the GSR 4.400 final drive ur goign to have to use a main shaft with a 4.400 gear on it. the ls 4.266 will not work.
Yes, this is correct! I put an ITR LSD in my LS tranny and this is what I had to do. The ITR LSD only bolts up to a 4.400 final drive gear. Seems easy enough to swap FD ring gears with a GSR/ITR, right? Wrong.
You also need a 4.400 countershaft from a 4.400 FD equipped car. Then you slide your LS gears onto that.
boosted_db8
Nov 9, 2012 07:15 AM
MShonda
Mar 6, 2012 07:02 PM
NA JDM GSR
Jun 11, 2007 07:39 PM
Mr.DC2TurBo
Aug 30, 2004 05:35 PM
Sukebei Oni
Apr 16, 2003 05:54 PM
