HELP CEL code 9.
Old Oct 24, 2003 | 08:09 AM
pulse_crx's Avatar
Default HELP CEL code 9.
90 Hatch w/ b16a1 and msd ignition
Car threw a couple codes today. 1, 2, 9, 23. Reset the ECU and it was only code 9. Seeing as I have msd ignition, which includes the distributor, what could the problem be? If I do have to replace the dist. Should I get another msd? Thanks
Old Oct 24, 2003 | 08:15 AM
EF_LSVtec's Avatar
Default Re: HELP CEL code 9. (pulse_crx)
does it still run? Anyway, to answer your question, no you dont have to replace your MSD...unless they're broke.
Old Oct 24, 2003 | 12:08 PM
pulse_crx's Avatar
ya, it still runs fine. Only at idle its a bit messed. It will go down to about 600, then back up to 1200, then down, then up. So what is the problem here? I dont know where to start? or if I have to replace anything.
Old Oct 24, 2003 | 12:11 PM
Scarface928's Avatar
From: Northern Virginia home of missing hondas, USA
Default Re: (pulse_crx)
I forgot what code 9 is but a foul tps sensor will make the engine idle up and down,also check the vacum lines from the top of the intake manifold(make sure there are no vacum leaks)will also cause the same problem
Old Oct 24, 2003 | 12:40 PM
JDM4DRVTEC's Avatar
Default Re: (Scarface928)
code 9 is the cyp sensor which is located inside the distributor, the only way around the problem is swapping out distributors. or finding a sub housing to replace the old one. if it revs up and down constantly the check the cold start valve.
Old Oct 24, 2003 | 12:48 PM
pulse_crx's Avatar
Ya, code 9 is the cyp sensor. Where can I find a sub housing to replace the old one? and where is the cold start valve so I can check it? Thanks again? So am I looking a getting a new distributor?
Old Oct 24, 2003 | 12:50 PM
Grease Monkey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scarface928 &raquo;</TD></TR><TR><TD CLASS="quote">I forgot what code 9 is but a foul tps sensor will make the engine idle up and down,also check the vacum lines from the top of the intake manifold(make sure there are no vacum leaks)will also cause the same problem</TD></TR></TABLE>
TPS sensor will not make the idle up and down buddy..
And I doubt you have a vaccumm leak because the fact that the idle going up and down is not high enough.
What harness are you using in the car?
Old Oct 24, 2003 | 02:23 PM
JDM4DRVTEC's Avatar
yeah if you cant find a used distributor then yeah you would need a new distributor. i can get brand new ones for like 450 or remanufactured ones for 290 year warranty or i may have a used one for like 200 so let me kow what you want to do
the cold start valve is on the side of the manifold below the throttle body you can take it off and twist inb the srew on the backside underneath the plate that is there or i can get new ones for 80.00 bucks so if you have any more questions let me know
Old Oct 24, 2003 | 02:25 PM
pulse_crx's Avatar
I found a used dissy off a 88-91 crx si. Will this work? It is in good condition, and I can get it for cheap. Ive read some posts on it, but nothing that was more in depth. If anyone knows that would help
Old Oct 24, 2003 | 02:30 PM
JDM4DRVTEC's Avatar
it may work but i dont recommend it, you will have to modify the distributor some how but im not sure
Old Oct 24, 2003 | 02:31 PM
pulse_crx's Avatar
ya, i posted another thread about it, and the posts there say no. I found a jdm dist in town so Ill see how that goes. Is this my only option to get rid of code 9?
Old Oct 24, 2003 | 04:40 PM
JDM4DRVTEC's Avatar
yes it is
Old Oct 24, 2003 | 05:33 PM
quis23's Avatar
Default Re: (JDM4DRVTEC)
i'm going throught the same thing right now(code 9),car idles fine ,but dies when i drive it and come to a stop. check your distributor and msd to see if you have any loose connections. also i beleive that you can use the 88-91 crz si ecu. hopefully i solve my problem this weekend and keep you posted.
AB16A2T
Sep 21, 2009 11:35 AM
ProjectEGSiR
Jun 10, 2008 03:44 PM
TinyTitan
May 3, 2007 09:05 AM
Green94GSR
Oct 13, 2003 04:27 PM
shotty
Sep 1, 2002 06:04 PM
