where does small washer in fuel filter go
part number 40 in this pic above the fuel filter is what I think you are referring to? there should be 2, one on each side of the fuel line connection.
Thanks fellas.
Christ man, two hours + later I have a new fuel filter. I couldn't get that ******* bottom bolt off for nothing. Learning experiece.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WayneGro »</TD></TR><TR><TD CLASS="quote">Christ man, two hours + later I have a new fuel filter. I couldn't get that ******* bottom bolt off for nothing. Learning experiece.
haha, yeah i had to remove the intake tubing and disconnect some wire harneses just to get my hand in there for leverage.
</TD></TR></TABLE>haha, yeah i had to remove the intake tubing and disconnect some wire harneses just to get my hand in there for leverage.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by magic hat #9 »</TD></TR><TR><TD CLASS="quote">
haha, yeah i had to remove the intake tubing and disconnect some wire harneses just to get my hand in there for leverage.</TD></TR></TABLE>
the first time was a bitch. i hope i dont have to do that again for a while
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrewCityR »</TD></TR><TR><TD CLASS="quote">Double A knows best.
Hell, find his fuel filter thread. Helped me out.
Double A ron, I can't find the thread. Which one are you referring to?
</TD></TR></TABLE>Double A ron, I can't find the thread. Which one are you referring to?
There is a fuel pressure port on some fuel filters-there is a 12mm bolt and the little crush washer-that may be what you are talking about.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cosworth »</TD></TR><TR><TD CLASS="quote">
Double A ron, I can't find the thread. Which one are you referring to?</TD></TR></TABLE>
Sean, https://honda-tech.com/zerothread?id=374586 .... and Fairbanks?! wtf!
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe »</TD></TR><TR><TD CLASS="quote">There is a fuel pressure port on some fuel filters-there is a 12mm bolt and the little crush washer-that may be what you are talking about.</TD></TR></TABLE>
correct.
to the original poster, were you using line wrenches?
correct.
