high pitch whining noise
Old Oct 23, 2003 | 11:35 AM
TSAngry's Avatar
Default high pitch whining noise
someone please help me. whenever the car is running and i listen to music, i hear a high pitch whining noise coming from near the driver side door panel. i have no idea what it is. can someone tell me whats wrong and how i can fix it? thanks.
edit: sorry forgot to put in audio forum. but can i get some help anyways. thanks.
Old Oct 23, 2003 | 11:42 AM
SMC Integra's Avatar
Default Re: high pitch whining noise (01GsR)
does that speaker work? It might be blown.
Old Oct 23, 2003 | 11:55 AM
tweekerz's Avatar
Default Re: high pitch whining noise (SMC Rice Rocket)
Alternator whine?
Old Oct 23, 2003 | 12:00 PM
purplegsr's Avatar
that usually happens because of how your ground wire is connected. I am not sure how to fix it though, it sounds louder when you accelerate right? Like it is connected to your engine almost?
Old Oct 23, 2003 | 12:09 PM
TSAngry's Avatar
Default Re: high pitch whining noise (purplegsr)
yea the speaker works and the whine does get louder when i accelerate. i have no idea what to do
Old Oct 23, 2003 | 02:47 PM
NuclearB18B's Avatar
supercharger?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purplegsr &raquo;</TD></TR><TR><TD CLASS="quote">that usually happens because of how your ground wire is connected. I am not sure how to fix it though, it sounds louder when you accelerate right? Like it is connected to your engine almost?</TD></TR></TABLE>
that could be the case. other factors to look into is if you have a system in there, running power and rca's next to each other will do that. if you do have a system, try running rca's and power wire on opposite sides of the car. if that's not possible replace the rca's with a shielded cable so it'll block the interference. also i've heard spark plug wires can cause the same problem. hope this helps
Old Oct 24, 2003 | 03:31 AM
JimBlake's Avatar
Unplug the speaker to see if the noise is actually coming from the speaker. If so, check the grounding of the stereo. Check where your speaker wires are going. Do they run alongside something that carries power? Maybe move them?
If the noise doesn't actually come from the speaker, you'll have to narrow down the location.
Old Oct 3, 2017 | 09:32 AM
Rose Healy's Avatar
I have 2008 Honda Element and have the same high pitched whine coming from driver side door started this morning
did you ever resolve this issue if so any help here would be greatly appreciated
noise is present even when vehicle is off
Old Oct 3, 2017 | 05:24 PM
tamboo's Avatar
10 Year Member
guessing that it's audio related. if so:
https://www.crutchfield.com/S-NjWcam...ion_guide.html
Old Oct 26, 2017 | 08:47 AM
tofuchicken's Avatar
10 Year Member
If you have an aftermarket system with an amp driving the door speakers it could be getting back feed from the alternator, check the ground at the amp.
if no amp then replace speaker. if problem persists its coming from the head unit.
Old Nov 6, 2017 | 07:07 PM
Kobly's Avatar
If you don't have your cd player properly grounded the whine will come through your speakers in the doors. Check your wiring. Make sure there is a good connection on the ground wire.
ph0shizzle
Audio / Security / Video
Sep 7, 2006 04:38 PM
honda95civic
12
Jun 21, 2006 11:03 AM
xSCTYGx
Nov 11, 2003 05:42 PM
watacivic
13
Oct 13, 2003 09:41 AM
IntEgRaxbOyx415
Jul 6, 2002 03:09 PM
