engine noise?
Old Jun 15, 2006 | 01:40 PM
honda95civic's Avatar
Default engine noise?
Hooked up my system and Im getting noise from the highs(polk momos) even with the car off.. in acc..
and its like a high wine noise.. and when i touch and move around the rcas at the back of the radio.. the noise changes and whatnot.
when i turn my gain up.. i get a very intense beating of the midranges back and forth violenty. (so i have it less then half now)
bad ground?
also running a cap if that matters
Old Jun 15, 2006 | 02:02 PM
nsxxtreme's Avatar
Default Re: engine noise? (honda95civic)
Sounds like you have a bad RCA wire.
Touch the ground of the RCA near your amplifier does the noise get louder?.
Which amplifier do you have?
If you have a kicker amplifier it explains your problem.
Old Jun 15, 2006 | 06:57 PM
sony224422's Avatar
Default Re: engine noise? (nsxxtreme)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxxtreme &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like you have a bad RCA wire.
If you have a kicker amplifier it explains your problem.</TD></TR></TABLE>
uhh..?
You probably have a bad ground. I would check the spot your grounding your amp to. And if possible try a different amp to test it. This happened to me when i fried my headunit.. so it could be your headunit too. I would personally check the amp ground first, and then swap out the headunit and see if it still does it.
Old Jun 15, 2006 | 11:49 PM
FullJDMEg's Avatar
it could be the way you ran your wires. did you run them all on the same side? (power, remote, RCA's)
if so keep the power and remote together (driver side) and the RCA's (pass. side)on the other side.
or like stated above bad ground or RCA's
Old Jun 16, 2006 | 04:34 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">uhh..?</TD></TR></TABLE>
Uhh what?? That's a perfectly valid thought. Definitely could be a bad RCA.
Old Jun 16, 2006 | 06:07 AM
Default Re: (B18C_EJ8)
kicker rcas. They were brand new.. but i guess sht happens.
i think its just a bad ground. I willlook today.
and rcas on pass side.. remote and power on othe side
Old Jun 16, 2006 | 07:11 AM
fcm's Avatar
fcm
Old Fart
Lets see, <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda95civic &raquo;</TD></TR><TR><TD CLASS="quote"> and when i touch and move around the rcas at the back of the radio.. the noise changes and whatnot.</TD></TR></TABLE> even if it turns out not to be the RCAs, it is the first thing I would check, not that hard to just run another set from the HU to the amp over the seats and everything.
I would also check the grounds, not just the amp but on the HU also. 94
Old Jun 16, 2006 | 08:13 AM
nsxxtreme's Avatar
Default Re: engine noise? (fcm)
The fact that he hears the noise when the car is not on leads me to believe he has a bad ground at the RCA. Either the RCA is bad, amp RCA ground input is bad, or reciever RCA ground output is bad.
If this is truely the case, by touching the RCA ground near the amp you will hear an audible change.
Kicker multi-channel amplifiers run the RCA ground through only one cable *idiots*
If you plug the RCA into channel 3-4 the RCA does not have a ground unless another one is plugged in 1-2. But you didn't mention which amplifier you have.
Old Jun 16, 2006 | 01:10 PM
kick 200.2 for polk momo components..
1000.1
kx amps. for 06 ...kicker rcas
Old Jun 17, 2006 | 06:42 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxxtreme &raquo;</TD></TR><TR><TD CLASS="quote">The fact that he hears the noise when the car is not on leads me to believe he has a bad ground at the RCA. Either the RCA is bad, amp RCA ground input is bad, or reciever RCA ground output is bad.</TD></TR></TABLE>I was agreeing with you. 94
Old Jun 18, 2006 | 06:04 AM
yea kicker rcas suck.. i get them for like 80%off thats y i bought them.. i went into my storage and got my rcas from mid 90s.. very heavy.. and very good. no more noise..
i do however have a slight thump in my speakers and my subs when i turn the volume to zero or turn the car off.
i only had that problem like once and that was with a crappy amp. i didnt check the amp grounds yet. could that be it?
Old Jun 20, 2006 | 09:35 PM
lsvtek's Avatar
is it like a hiss noise? If it is then u can get this lil adapter that connect to ur rca calbes then it goes into ur amp. It is kinda like a filter were it stops the noise it worked for me
Old Jun 21, 2006 | 11:03 AM
Default Re: engine noise? (4drlsintegra)
yea its called a ground loop isolator. we can close the thread cuz my problems are gone..
better ground.. and better rcas
ph0shizzle
Audio / Security / Video
Sep 7, 2006 04:38 PM
devilpuppy
22
Jul 22, 2004 06:34 AM
PetroGuyX
Jul 11, 2003 09:30 PM
bzyrice
May 15, 2003 09:24 PM
Unjockable
May 31, 2002 11:08 PM
