Valve cover spark plug seals
Old Oct 23, 2003 | 11:27 AM
CRX Si's Avatar
Default Valve cover spark plug seals
Are the replacible? I just got my Z6 cover and one of the seals has a tear in it, They look like they are pressed in so i dont know how hard it would be to replace...
Old Oct 23, 2003 | 11:28 AM
revhigh89's Avatar
Default Re: Valve cover spark plug seals (CRX Si)
goto the honda dealer, should cost u from 5 bucks-20 bucks for that little seal
Old Oct 23, 2003 | 12:00 PM
CRX Si's Avatar
Default Re: Valve cover spark plug seals (evilryu530)
cool, but how do you get them in? Do they have to be pressed in?
Old Oct 23, 2003 | 12:07 PM
Outsane's Avatar
just push them in with your fingers...
Back in my more ghetto days I would pull the old ones out and lay in a cut rubber band string in the well and put the seal back in..
instead of buying new seals..
Old Oct 23, 2003 | 12:24 PM
EL Vap133's Avatar
Take your valve cover off, take out the old seals, replace it with new seals, and slap the cover back on. Some people like to use a dab of sealer, make sure your valve cover gasket is good as well...
Old Oct 23, 2003 | 04:56 PM
CRX Si's Avatar
Default Re: Valve cover spark plug seals (EL Vap133)
cool, thanks guys... The cover is loose cause it is for my mini-me in the making so it wont be that hard... Thanks again
Old Oct 23, 2003 | 05:01 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Si &raquo;</TD></TR><TR><TD CLASS="quote">cool, thanks guys... The cover is loose cause it is for my mini-me in the making so it wont be that hard... Thanks again</TD></TR></TABLE>
Remember, when you tighten the nuts on the valve cover, not too tight or you might break the grommets...
Old Oct 23, 2003 | 06:30 PM
CRX Si's Avatar
cool, thanks for the help...
Old Oct 23, 2003 | 06:44 PM
91 POS's Avatar
Are you talking about the O-ring looking things? If so dose anyone know what size O-rings to use for the gaskets?
brucepick
Jan 22, 2011 08:51 PM
Ritchie
12
Dec 21, 2006 07:29 PM
budget
Apr 11, 2006 05:34 PM
blackflag188
Nov 9, 2004 04:54 PM
CalvitoSol
Jul 8, 2002 12:03 AM
