replacing tube seals
I just got some new tube seals (spark plug gaskets), because im leaking oil onto my spark plugs like crazy. But I was wondering if i should just wait and get a new valve cover gasket before I do this.
Chris
Chris
Re: replacing tube seals (ebelp)
where are the old tube seals and where do the new ones go, i'm replacing mine right now and when i took it off and out i see no tube seals, so i dont know where to put my new ones.
Re: replacing tube seals (DrewQ1)
if ur spark seals are leaking right now, go ahead and change them with the new ones. the valve cover gasket's dont really go bad. i have pulled my valve cover many times and am still using the stock valve cover seal. if ur valve cover seal is leaking then replace it but i would go ahead and replace those spark seals right away if there leaking
gr8gatzby
11-11-2006 08:35 AM
themorphious
06-03-2006 12:14 PM
standbackimapro
04-29-2006 05:38 PM
