boosting a sohc tips
Old Oct 22, 2003 | 06:39 PM
eg ferio's Avatar
Default boosting a sohc tips
i have a ferio eg thats auto.....my plans are to do a auto to manual conversion and then boosting it,i would like to know some tips for me to be able to boost more and make my car run harder without having to blow it
Old Oct 22, 2003 | 06:42 PM
mycivicstoo(s)low's Avatar
Default Re: boosting a sohc tips (eg ferio)
good fuel management
How much boost do you plan to run?
Old Oct 22, 2003 | 06:55 PM
CivicFerioSiR's Avatar
this is a good question for angryblacksedan to answer. ill get him to reply.
Old Oct 22, 2003 | 07:04 PM
eg ferio's Avatar
Default Re: boosting a sohc tips (mycivicstoo(s)low)
well i heard that u can only boost like 7 to 8 pounds but i want to be able to pick the boost up a notch safely
Old Oct 22, 2003 | 07:06 PM
Ricey McRicerton's Avatar
Good fuel management and tuning. A stock clutch (d series) is only good to about 7 or 8 psi on a TDo4h-15g (from personal experience).
Old Oct 22, 2003 | 07:07 PM
Navid OG's Avatar
Default Re: boosting a sohc tips (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">Good fuel management and tuning. A stock clutch (d series) is only good to about 7 or 8 psi on a TDo4h-15g (from personal experience). </TD></TR></TABLE>
couldnt say it better myself........
Old Oct 23, 2003 | 07:16 AM
eg ferio's Avatar
any other suggestions?
Old Oct 23, 2003 | 07:24 AM
JICEK9's Avatar
Default Re: (eg ferio)
with good fuel management
9psi... single cams are cheap
Old Oct 23, 2003 | 07:26 AM
allmtr's Avatar
if i could take it all apart, id get new bearings, and rod bolts.
but if i just bought the turbo, id definately get all the fuel components needed, (pump, fpr, injectors, rail, etc...) and tune the f**k out of it y0!
Old Oct 23, 2003 | 10:04 AM
nhez's Avatar
all i can say is take ur time setting a goal and set-up. although weak,a d can still be very potent. after setting a goal, that will determine what set up u should go with. management & tuning is the key. good luck
Old Oct 23, 2003 | 10:23 AM
SOHC_MShue's Avatar
I would suggest doing plenty of searches in the forced induction forum for a couple of months before you even think about putting a turbo on your car.
Old Oct 23, 2003 | 10:24 AM
poison's Avatar
I would say on a budget, get DSM 450 cc injectors, wire up a resistor box, run the V-AFC and provided you richen up certain RPM's (like higher RPM's), it could be possible to run 10 psi provided you still have fair condition rings.
Old Oct 23, 2003 | 12:09 PM
boostsohfast's Avatar
Default Re: boosting a sohc tips (poison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">I would say on a budget, get DSM 450 cc injectors, wire up a resistor box, run the V-AFC and provided you richen up certain RPM's (like higher RPM's), it could be possible to run 10 psi provided you still have fair condition rings.</TD></TR></TABLE>
Thats what I'm doin. I do have head studs, a cometic HP style headgasket, and only a tiny greddy 15g turbo but its a blast. 13.62 in my EH3 at about 8 psi... Still running un-tuned though.
Old Oct 23, 2003 | 12:12 PM
Default Re: boosting a sohc tips (boostsohfast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostsohfast &raquo;</TD></TR><TR><TD CLASS="quote">
Thats what I'm doin. I do have head studs, a cometic HP style headgasket, and only a tiny greddy 15g turbo but its a blast. 13.62 in my EH3 at about 8 psi... Still running un-tuned though. </TD></TR></TABLE>
Amen...Im on a stock block and 8 psi (same 15g) and ran a 13.8 in a stripped out hatch.
EDIT: Make sure to learn as much as you can before you jump into this. It is a BIG project and you will end up paying an arm and a leg if you plan on paying other people to fix everything that can/will break.
Old Oct 23, 2003 | 12:13 PM
poison's Avatar
Sweet, how long have you been running that and how many miles are on your motor?
Good times already and still untuned
Old Oct 23, 2003 | 12:19 PM
loweredhopes's Avatar
http://www.turbod16.com after my manual swap im doing the greddy kit with a type 31 front mount and the greddy emanage with laptop tie in... im waiting for a responce from greddy on what injectors they recomend... i heard the rc eng. work great... plan on dropping like 2500 to do it right with all the goodies
Old Oct 23, 2003 | 12:33 PM
The Internet Tough Guy's Avatar
Default Re: boosting a sohc tips (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">I would suggest doing plenty of searches in the forced induction forum for a couple of months before you even think about putting a turbo on your car. </TD></TR></TABLE>
absolutely. also i recommend you read maximum boost by corky bell - best $25 you can spend toward a turbo setup
Old Oct 23, 2003 | 12:42 PM
Default Re: boosting a sohc tips (loweredhopes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loweredhopes &raquo;</TD></TR><TR><TD CLASS="quote">http://www.turbod16.com after my manual swap im doing the greddy kit with a type 31 front mount and the greddy emanage with laptop tie in... im waiting for a responce from greddy on what injectors they recomend... i heard the rc eng. work great... plan on dropping like 2500 to do it right with all the goodies</TD></TR></TABLE>
Im not real enthused about my E-Manage. Biggest pile of junk if you ask me. The manual I was supplied with is in Japanese, so I had to do some legwork to find an english one (someone on here was nice enough to help me out.) Then the ***** that are supossed to tune wahtever RPM range are not worth a half a crap. I would stay far far away from that E-Manage. Just my opinion (and I own one). Also, that Corky Bell book was my daily read for a couple of months before I bought my turbo!!
Old Oct 23, 2003 | 01:43 PM
Good times already and still untuned </TD></TR></TABLE>
Been running the turbo for 14 months now and odometer reads 183k. Car weighed in at 2474 with me in it on the 13.62 run with street tires. Absolute full interior + spare.
Old Nov 5, 2003 | 04:59 PM
Snail Tuning's Avatar
im running 7psi stock engine dsm450s and vafc no problems hear. soon to be running 10psi might retard the timming some before i hit 10psi.
Old Nov 5, 2003 | 05:21 PM
Quad-Damag's Avatar
Default Re: boosting a sohc tips (bmcc72)
I run 10 psi on my automatic y7, it's slow tho
Old Nov 5, 2003 | 05:26 PM
pdiggitydogg's Avatar
its all in the tuning
corn juice
Jan 16, 2012 04:42 PM
JDM_EH2
Jul 22, 2004 06:55 PM
djickabod
May 9, 2004 11:28 PM
Insperation
Feb 4, 2004 09:33 AM
havok hybrid
Sep 4, 2002 10:33 PM
