JDM D15B just arrived???
Old Oct 22, 2003 | 05:39 AM
japspecjohn's Avatar
Default JDM D15B just arrived???
I recieved my jdmD15B yesterday and it was an automatic motor....I can just throw any D series fly wheel on correct? It came with a P08 how do I know if its auto too? Are the check engine lights the same as the US ecu? I plugged the ECU into my car seems to run the same but with a check engine prob for vtec and 1 wire O2 (i have a dx with 4 wire currently) and maybe auto code?
Any help would be appreciated
thanks
Old Oct 22, 2003 | 05:48 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: JDM D15B just arrived??? (japspecjohn)
CELs are the same for JDM and USDM.
Check the codes and get back to us with them if you can.
Old Oct 22, 2003 | 05:49 AM
SOHC_MShue's Avatar
i'd send it back and get a manual.
Old Oct 22, 2003 | 05:55 AM
monicle's Avatar
If there are 4 ecu plugs then the ecu is auto. Yes you can throw your clotch/flywheel on just take of the torque converter and plate. Make sure you use the flywheel bolts from the MT cause they are different than the AT ones. Some auto motors use different cams but I dont know for sure on this motor.
::edit:: I mean if the ecu is pinned for 4 plugs
Old Oct 22, 2003 | 05:56 AM
Default Re: JDM D15B just arrived??? (SOHC_MShue)
Also on USDM motors on the back right corner of the intake manifold is a sensor with a vaccume line and a plug (black little round cylinder thing).....on the D15b theres no spot for it do I need it when running the P08?
The ecu only has 3 plugs...but My sister uses an auto p28(now chipped ran fine both ways threw CEL when unchipped) in her sol and thats 3 plugs too.
Modified by japspecjohn at 4:10 PM 10/22/2003
Old Oct 22, 2003 | 07:08 AM
bump
Old Oct 22, 2003 | 09:24 AM
Default Re: (japspecjohn)
bumpity bump i need answers hehe
Old Oct 22, 2003 | 10:11 AM
BauleyCivic's Avatar
Risky Business
All I know is that most longblocks are auto's...when my friend ordered a B16 longblock it was auto
Old Oct 22, 2003 | 10:16 AM
goodbyegti's Avatar
im pretty sure my ecu has three plugs as well and is p08 running a JDM D15b manual...
Old Oct 22, 2003 | 03:58 PM
Default Re: (goodbyegti)
p08 is 3 plug
p28 auto and manual is 3 plug
Old Oct 24, 2003 | 06:30 AM
1990hondaHF's Avatar
He has a code 19...if he has an auto p08 ecubeen there done that!!!...you need to get a 5 speed p28 or a p08....p28's work identical to the p08 and are 1000 times easier to find.
Old Oct 24, 2003 | 09:29 AM
Default Re: (1990hondaHF)
yeah i got code 19 and the 2 vtec codes i forget them at the moment.....(i plugged it in on my dx motor to make sure it worked) Runs fine.
Old Oct 24, 2003 | 10:33 AM
If you would like to get a 5 speed P28 I have one for sale....$250.00 shipped OBO....
Old Oct 24, 2003 | 11:33 AM
Jonathan_ED3's Avatar
Where did you order the d15 from?
Old Oct 24, 2003 | 11:37 AM
dantastic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by japspecjohn &raquo;</TD></TR><TR><TD CLASS="quote">Also on USDM motors on the back right corner of the intake manifold is a sensor with a vaccume line and a plug (black little round cylinder thing).....on the D15b theres no spot for it do I need it when running the P08?
most jdm motors dont have the evap purge solenoid and dont use the charcoal canister system (that black can deal on the firewall). if u use a p28, i think u can just plug the solenoid into the harness, and leave the vaccum lines unplugged
Old Oct 24, 2003 | 02:16 PM
Default Re: JDM D15B just arrived??? (dantastic)
i got the motor from http://www.japandomesticmotor.com ...p28 for 250 is a little steep i can get one for 75 easy around here.
Old Oct 24, 2003 | 09:14 PM
sorry, I should have put $125...that is $125...
Old Oct 28, 2003 | 06:24 AM
Default Re: JDM D15B just arrived??? (1990hondaHF)
good news they are sending me a manual ecu when they get one in props to http://www.japandomesticmotor.com fast shipping great service
nycpatron
Feb 15, 2014 11:23 AM
maverick32
Aug 3, 2009 11:53 AM
radeonboy
Aug 12, 2004 07:19 PM
Project92Hatch
Mar 30, 2003 11:58 AM
Zeus Zore
Apr 1, 2002 03:06 PM
